Libra_Lyn
Advice On Shifting Toilet Dr+tempered Glass Dr/wc Semi-choke
:help: New to this forum but can see alot active threads hence posting my issues, need advice, pls share :)
a) Plan to shift Toilet Door, no idea how to start. Should I look for contractor , don need ID rite? Any recommendations? Will require wood hacking as intended Door location currently has bed fixtures blocking. Don think I need any ID for such job rite?
b) Any Advice on installation of Tempered Glass as Toilet Door? Any Pros & Cons? As I read from other threads, shifting of WC is not advisable/possible. Planning to shift Toilet Door to beside the WC since cant shift WC=narrow entrance, shower area will be @ far end hence I guess no worries on shower water affecting Toilet Door.
c) My WC is semi-choke...actually because a broken toilet brush head was flushed down before, I guess it is somewher, duno where exactly but still existing & causing difficulty in flushing stools, only fluid waste possible. Any idea how much will it cost for plumber to fix this problem? Is it need remove WC to resolve??
