ccube1982
Need Quote For My Existing 4"A" Flat
If you are an ID, please drop me a quote for the following items @ ccube1982@gmail.com, thanks. I like to do up my place start either early or mid Jun.
Requirements
Professional Services
1 Space Planning & furniture Layout
2 Design Consultation
3 Furnishing Consultation
4 Perspective Drawing On Carpentry Works
5 Materials & colour Proposal
6 Project Management & Site Supervision & Audit
7 Warranty With Guaranteed After Sales Service
Demolition & Hacking Works
1 To hack away existing floor tiles & tiles skirting @ living, dining room & store room.
2 To hack away existing floor tiles & tiles skirting @ 3 bedroom.
3 To dismantle existing 3 bedroom & storeroom door frame.
4 To hack away existing floor & wall tiles @ kitchen.
5 To dismantle existing kitchen cabinet, stove & sink support
7 To hack away existing floor & wall tiles @ master & common toilet.
8 To dimantle existing toilet accessories @ master & commom toilet.
9 To dismantle door & door frame @ master & common toilet.
10 To dismantle living room & masterbed room cornices
Sub Total: $-
Mansory Work
1 Supply & lay 600mm x 600mm polished Homogenous tiles @ Living & Dining &
store room. (390 Sqft) Included:
-main door kerb finish
-tiles skirting
2 Supply & lay 600mm x 600mm polished Homogenous tiles @ 3 rooms.
(490 Sqft) Included:
-door kerb finish
-tiles skirting
3 Supply & lay 300mm x 600mm non-slip homogenous flooring @ kitchen
(140 Sqft) Included:
-Laying concealed drainage pipe for Kitchen sink.
-Laying concealed drainage pipe for washing machine.
4 Supply & lay water proofing membrane @ kitchen. (Approved by HDB)
-1st layer = laying K-11 water proofing
-2nd layer = laying water proofing 3 in 1 cement
-3rd layer = laying Non-shrink grout water proofing cement
5 Supply & lay homogenous/ceramic wall tiles up to ceiling height @ kitchen.
(180 Sqft) Included:
-make good defect area @ kitchen entrance.
6 To construct kitchen cabinet mortal base.
7 To construct fridge & washing machine cabinet base in tiles finish.
8 Supply & install flat stainless steel rubbish chute.
9 Supply & construct low wall to support L-shape kitchen cabinet, finished by:
-63mm cement block
-In tiles finish
10 Supply & lay 300mm x 300mm non-slip homogenous flooring @ both bathroom.
Included:
-toilet entarnce door kerb.
-20mm step down shower kerb finish.
-Laying concealed drainage pipe for shower area
-Laying concealed drainage pipe for wash basin
11 Supply & lay water proofing membrane @ both bathroom. (Approved by HDB)
12 Supply & lay homogenous/ceramic wall tiles up to ceiling height @ both bathroom.
(447 Sqft) Included:
-make good defect area after hacking @ bathroom entrance
13 Supply & lay homogenous tiles (non-slip) for 2 step staircase.
Sub Total: $-
Plumbing Work
1 Replacement of standard stainless steel piping. (Cold Points)
2 Installation of 2 sets toilet bowl for labour charges only.
3 Installation of 2 sets toilet basin & tap for labour charges only.
4 Installation of 2 no's instant heater for labour charges only.
5 Installation of whole house accessories for labour charges only.
6 Installation of 1 no'stainless steel kitchen sink & tap for labour charges only.
7 Supply 1 no' stainless steel kitchen sink & tap. (Optional)
8 Supply 2 no's of toilet bowl (water saver), basin & tap. (Optional)
9 Supply & change main sewerage pipe (To be approved by HDB)
10 Supply & install 1 no' wash basin in kitchen area (Optional)
Sub Total: $-
Door Works / Window Works
1 Supply & install 1 no's 3ft x 7ft solid nyatoh main door, finished by:
-main level door lock
-stainless steel door stopper
-eye viewer
-non fire-rated finish
2 Supply & instal 4 no's solid nyatoh bedroom door frame according to existing doors'
measurements
3 Supply labour to re-install 4 no's 3ft x 7ft solid nyatoh bedroom door, included new:
-door lock
4 Supply & install 1 no's 3ft x 7ft wrought iron main gate, finished by:
-Non Galvanize finish
-Include lock
5 Supply & install 2 no's aluminium frame bi-fold door in powder coated & acrylic glass
finish @ both toilet.
6 Supply & install Silver aluminium sliding window in embossed glass finish @
living area. (3 or 4 way track) (46 Sqft)
7 Supply & install Silver aluminium sliding window in embossed glass finish @
bedroom 3. (3 or 4 way track) (59 Sqft)
8 Supply & install Silver aluminium casement window in embossed glass finish @
kitchen. (3 panel) (32 Sqft) (Optional)
9 Supply & install Silver aluminium casement window in embossed glass finish @
master bedroom. (2 panel) (18 Sqft) (Optional)
10 Supply & install Silver aluminium casement window in embossed glass finish @
bedroom 2. (2 panel) (18 Sqft) (Optional)
11 Supply & install Silver 48" x 24" adjustable louver window in wire glass
finish @ master & common toilet.
12 Supply & install 1 no's aluminium overhead sliding door in powder coated & acrylic glass
finish @ kitchen entrance.
13 Supply & install tempered glass shower screen @ master bedroom.
Sub Total: $-
Misc. Work
1 To paints whole unit wall & ceiling using Nippon all-in 1 paints. (Unlimited Colour)
Included:
-main door frame = sand & re-vanish or paint glossy paints
-all door = sand & re-vanish or paint glossy paints
-all door frame = sand & re-vanish or paint glossy paints
-whole house severage UPVC pipe = paints gloosy paints
-To touch/plaster up where necessary whole unit wall & ceiling defect area.
2 To lay protection sheet @ living room & all bedroom.
3 Chemical wash & general wash for whole house. (move in condition)
4 Uplifting sand & material & debris fees.
5 HDB permit handling
Sub Total: $-
Carpentry Work
1 Designed & fabricate kitchen cabinet C/W drawer, cultery tray, in laminate &
ABS trimming & soft closing system finish by:
-Top Unit (12ft)
-Bottom Unit (15ft)
-Solid surface worktop. (15ft)
-Stainless steel disk rack
-1 panel frosted glass with aluminium frame
-1ft box up piping tall unit
2 Supply & install 1 x hob unit
3 Supply & construct wardrobes @ 3 rooms. (Optional)
4 Supply & construct shoe cabinent. (Optional)
5 Supply & construct TV console. (Optional)
Sub Total: $-
Electrical Work
1 Supply & install new DB switch board (12 way)
2 Rewiring of whole house (Optional)
3 Run 2 x light point & reinstate the existing 8 light point
4 Reinstate 9 lights.
5 Run 3 x SCV points
6 To reinstate 2 tel point
7 To install 15 double points
8 Supply & install Inverter Aircon for 4 rooms with power points & piping works. (Optional)
Sub Total: $-
Other Work
1 Supply & construct false ceiling for bedroom passage way.
2 Supply & construct L-box for living room & 3 rooms.
3 Supply & construct L- shape rack in store (4 levels).
Sub Total: $-
Total Amount Quoted: $-
Less Discount:
Total Amount: $-
