fiona87
Help With This Quotation
Please help me see whether I got chop or not for this quotation. TIA!
Professional services
Design Consultation & Space Planing Complimentary
Design Proposal & Perspective Drawing Complimentary
Selection of colour, material & accessories Complimentary
Site Co-ordination & Supervision Complimentary
Decorative Advice Complimentary
Masonry/Tiling Works
Supply material & lay cement screeding living floor
Supply & install 600m x 600mm polished homogeneous floor tiles for living & dining hall $1,440.00
>selection of tiles up to $3.00 psf
>excluding: Borders/special tiles
>est.240sqft inclusive of wastages
Supply labour & material to make good at damage area $600
Laying of polished homogeneous skirting for living & dining hall $180
Supply & construct cement mortar kitchen cabinet base finish with side tiling work $300
Supply & construct cement mortar washing machine base finish with full tiling work $90
Supply & construct cement mortar fridge base finish with full tiling work $90
Supply & construct 2 nos of shower kerb $180
Glass Works
Fabricate & install 1 set of est. (L)1500mm x (H)1800mm Frameless 10mm clear tempered $450
glass shower screen at master bathroom
>10mm(thk) Clear glass
>1 set of fixed panel
>1 set swing door
glass shower screen at common bathroom
>1 set swing door
Fabricate & install 1 set of est. (L)2700mm x (H)700mm Frameless 6mm tempered glass backing $780
Fabricate & install 1 set of est. (L)3ft x (H)(5ft) 5mm clear mirror at master bathroom $300
Fabricate & install 1 set of est. (L)3ft x (H)(5ft) 5mm clear mirror at common bathroom $300
Carpentry Works
Design, fabricate & install (L)24ft kitchen cabinet in solid-ply finish with high grade $2,640
AMIRA 2011 laminate comes with:
>ABS trimming casement doors
> 1 no. of 2 tier dish drainer
> 1 no. of cutlery tray
> 1 no. of sand-blasted glass panel
Design, fabricate & install est. (L)6ft x(H)6ft feature wall in solid-ply finish with high $1,080
grade AMIRA 2011 laminate ****
Design, fabricate & install est. (L)6ft Tv console in solid-ply finish with high grade $720
AMIRA 2011 laminate c/w drawing ****
Design, fabricate & install est. (L)4ft Full height display cabinet in solid-ply finish with high $1,120
grade AMIRA 2011 laminate c/w casement door ****
Design, fabricate & install est. (L)6ft Full height walk in wardrobe in solid-ply finish with high $1,380
grade AMIRA 2011 laminate c/w internal carcass colour polygon board at master bedroom
Design, fabricate & install est. (L)3ft dressing table cabinet in solid-ply finish with high $450
grade AMIRA 2011 laminate c/w drawer door
Design, fabricate & install Top & Bottom est. (L)6ft Bar counter in solid-ply finish with high $780
grade AMIRA 2011 laminate at kitchen
Design, fabricate & install est. (L)3ft Study table in solid-ply finish with high $390
Design, fabricate & install est. (L)3ft bookshelf in solid-ply finish with high $450
Design, fabricate & install est. (L)3ft suspended vanity cabinet in solid-ply finish with high $360
grade AMIRA 2011 laminate at master bathroom
grade AMIRA 2011 laminate at common bathroom
Window works
Supply & install est. (L)8ft x (H)4ft aluminum sliding grille at master bedroom $224
Supply & install est. (L)6ft x (H)4ft aluminum sliding grille at common bedroom $168
Supply & install est. (L)8ft x (H)4ft aluminum sliding grille **** hall $224
Laminate Flooring
Supply & construct est. 70sqft 125mm raised platform finish with "Superme" laminate $1,010
flooring at master bedroom with light holder
Supply & lay "Superme" laminate flooring at master bedroom 60 (sqf) including wastage $240
Supply & lay "Superme" laminate flooring at bedroom 2 110 (sqf) including wastage $440
Solid Surface Works
Custom-made & install est. (L) 17ft of solid surface kitchen cabinet & vanity top $1,360
Plumbing Works
Supply labour & material to extend water pipe to new sink point $120
Supply labour to install 2 set of bathroom accessories $100
Laying of 2 conceal drainage pipe for kitchen sink FOC
Laying of 2 conceal drainage pipe for washing machine FOC
Supply labour to install 1 set of kitchen sink c/w tap $90
Supply labour to install run hand spray point at 2 bathroom $90
Supply labour to install 1 set of gallon heater $80
Supply labour & material to extend water pipe to gallon heater point $180
Ceiling Work
Design & construct island ceiling c/w curtain pelmet **** $750
Painting Work
Painting of whole unit using Nippon Paint (choose of 5 colour) $1,000
Electrical work
Supply & install 18 nos. of lighting points $630
Supply labour to install 25 nos. of lighting fitting(provided by owner) $250
Re-place & hacking existing 3 lighting point $180
Supply labour to install 1 no. of hanging light at dining area $45
Supply labour to install cooker hood point $100
Miscellaneous Work
Fabricate & install est.(L)8ft x (H)5ft aluminum sliding window at service yard area $600
Corrogated paper for (Protection) $80
Chemical wash upon works completion $250
HDB Renovation Permit fee FOC
Discount $101.00
Total for my 3 room quotation is $23,000
Is it reasonable? Please comment
hi,
i am not sure if its reasonable..
but i somehow find it attractive?
care to share which id or contractor?
cos i m finding 1 myself..
and if the finished works is good, fast n as promised, i might juz opt for this deal.
tx!
That sure is a long long list. Most of the carpentry work looks very reasonably priced, at least to me it is.
At $2.6k for the kitchen cabinets & $1.3k for the closet ... wow. hope the materials and workmanship is good.
Check the quality of materials! that's where they can CHOP.
and $720 for a 6ft tv console? amazing! do their designs look good?
final quantum amount looks like a lot, but then again, you are getting the whole place all done up.
Get the ID company to give a better discount la, otherwise, push them for free washing machine, microwave, that kinda thing.
Thanks for the reply!!
I'm not sure whether the workmanship good anot. But there will be warranty for 5 yrs.
So I don't think there will be any problem ba..
But I got from the other ID company the total is $22K plus which come with hood n hod and kitchen sink.
and there will be more things add in. and I like the design more.
the material might not be as good as others leh.. i dont know la... as i am also sourcing for others..
more or less i have confirmed to get TIP - The Interior Place @ Macpherson.. you can look for Eric Kwek @ 82003762.
he is one of the best contractor i found so far.. responsible with 3 yrs warrently..
