CuTeDuDe
Reno Quotes - Please Advise!
Hi all,
recently got a quote from my I/D for my 5rm resale flat.
mostly doing the whole kitchen and toilets.
As we are doing renovation for the first time hope that you guys could advise us on these quotes.
Thanks!.
A HACKING WORK Lump Sum $2,600.00
1 To supply labour to hack wall at kitchen
2 To supply labour to hack and create extra entrance at common bathrroom
3 To supply labour to hack kitchen & service yard floor tiles (wall tiles will be overlay)
4 To supply labour to hack wall tiles at Kitchen (only to exposed area, existing
wall tiles cover by new kitchen cabinet will be maintain) $350.00
5 To supply labour to hack both bathrooms' floor & wall tiles
6 To supply labour to dismantle existing cornices at whole house and arch
at balcony beam
7 To suply labour to dismantle kitchen cabinet and 3nos. Wardrobe
8 To supply labour to dismantle whole house window grille
(Note : price does not include of P.E. ENDORSEMENT fees if hacking
of wall required by HDB. Estimation of P.E. FEES est. $500 to $600)
B MASONRY WORK
1 To supply labour to make good wall with cement at :-
a Kitchen Entrance Wall $100.00
b Common Bathroom $100.00
2 To supply labour to make good floor and matching marble skirting at $200.00
kitchen entrance wall
3a To extent and construct 63mm thk hollow block wall at common bathroom $450.00
entrance ( 2 panels wall include of wall next to common bathroom's door)
3b To construct & seal existing entrance at common bathroom with 63mm $300.00
thk hollow block wall in cement finished
3c To supply & extent kitchen wall with 63mm thk hollow block wall in cement $500.00
finish include of false beam at kitchen entrance
4 To supply labour to provide grinding and polishing to whole house marble $1,000.00
5 To supply & lay matt homogeneous floor tiles ($3/sft) at :
a Kitchen $1,200.00
b Service Yard $700.00
c M/Bathroom $480.00
ci Shower kerb at M/Bathroom $100.00
d Common Bathroom $480.00
6 To supply & lay waterproofing at :-
a Kitchen $150.00
b Service Yard $150.00
c M/Bathroom $150.00
d Common Bathroom $150.00
7 To supply & construct kitchen cabinet base c/w tiles $380.00
8 To supply & lay homogeneous wall tiles ($3/sft) till 8ft ht at :-
a M/bathroorm $1,900.00
b Common Bathroom $2,050.00
c Kitchen (exposed wall only - not cover by new kitchen cabinet) $1,150.00
d Service Yard base on 900mm Ht $1,350.00
C CEILING, PAINTING AND PLUMBING WORK
1 To supply & construct false ceiling @ living, dining hall and passage way $1,400.00
and light cove @ living hall
2 To supply & box up balcony's pipe with partition board and in paint finished $280.00
3 To plaster (smoothen thef wall) whole house wall & ceiling with ultra $2,400.00
hard compound. corner of wall cover with beading (to prevent crack at corner)
4 To paint plastered wall and ceiling (to prevent water mark and mould) $300.00
5 To supply labour & paint for whole house with ICI/Nippon with original $1,450.00
paint. Price include of piping & gate (Col : 5 + 1)
6 To supply & construct S/Steel pipe to kitchen & both Bathroom $600.00
7 To supply labour only to install :-
a 1no.. Kitchen sink & sink tap $90.00
b 1no. w/m inlet & outlet $40.00
c 2nos. Instant heater and 2 way tap $200.00
d 2nos. Sitting to sitting w/c $180.00
e 2nos Spray gun $60.00
f 2nos. Basin & basin tap $180.00
g 2 sets bathroom accessories $60.00
8 To provide chemical washing to whole house include $280.00
9 To supply labour to protect existing marble floor (whole house) with $150.00
ply wood at hacking area) and paper roll to whole house
D DOOR WORK
1 To supply & install 1no Bi-fold door with white powder coated frame and $230.00
acrylic panel at Service Yard
2 To supply & construct 10mm tempered frameless swing door with clear glass
and in frosted film finish at :-
a Master Bathroom entrance $460.00
b Common Bathroom entrance $460.00
3 To supply & construct 10mm tempered clear glass showerscreen with $400.00
1 fix and 1 swing panel at master bathroom
4 To supply & construct 10mm tempered clear glass sliding door c/w $800.00
top track and handle at kitchen entrance (price include frosted film strip)
5 To design & construct 4nos. Veneer door c/w lever handle & s/steel stopper $1,480.00
viewer and s/steel stopper
6 To design & construct 1no. Solid nyatoh veneer door c/w press lock, door $1,450.00
(main door with half hour fire rated)
7 To supply & change wrought iron gate's lockset include of handle only $120.00
(subject to actual site)
8 To supply & install wrought iron window grille at :-
a Living Hall $630.00
bi Study Room (only for top portion) $450.00
bii Study Room (bottom) $200.00
c Master Bedroom $250.00
d Bedroom 2 $520.00
e Bedroom 3 $580.00
f Service Yard $1,120.00
g Kitchen (fix grille) $120.00
9 To supply & install window with silver frame and clear glass at :-
a Living Hall - Sliding (advise 2 track - 4 panels window) $600.00
b Study Room (top & bottom) - Sliding (top : 3 track ; bottom : 2 track) $720.00
c Master Bedroom - Casement $290.00
d Bedroom 2 - Sliding (3 track - 3 panels window) $630.00
e Bedroom 3 - Sliding (advise 2 track - 4 panels window) $570.00
f Service Yard $1,400.00
fi Sliding (advise 2 track - 4 panels window)
fii casement (bottom without window)
g Kitchen - Casement $130.00
10 To supply & install adjustable louver window with silver frame & wired glass :
a M/bathroom $240.00
b Common Bathroom $240.00
E CARPENTRY WORK
KITCHEN
1 To supply & construct kitchen cabinet on 37ft run with ABS trimming door & $4,440.00
internal with solid ply :
* Handles ; * soft closing hinge (in house brand)
* Set of 4 drawers (in house soft closing runner)
2 To supply & construct tall cabinet to box up sewerage pipe $150.00
3 To supply & install Indian Granite top base on 18.5ft length $2,220.00
4 To supply & install tempered glass backing base on 18.5ft L x 2.5ft Ht $1,110.00
Living Hall And Dining Hall
1 To design & construct low settee c/w storage and cushion base on 4.5ft L $720.00
2 To design & construct 8ft L x full ht t.v feature wall $1,680.00
3 To design & construct 6ft L suspended t.v. console $900.00
4 To design & construct shelving without backing and door at recess area F.O.C
Master Bedroom, Bedroom 2 And Bedroom 3
1 To design & construct casement wardrobe in laminate finished c/w
* Set of 4 drawers (with extention runner) *soft closing hinge (in house brand)
a Master Bedroom : 6ft L x full Ht $1,500.00
b Bedroom 2 : 6ft L x full Ht $1,500.00
c Bedroom 3 : 6ft L x full Ht $1,500.00
Bathrooms
1 To design & construct vanity cabinet base on 5ft L at Master bathroom :
a suspended bottom cabinet $650.00
b solid surface top $380.00
c frameless mirror base on 5ft L x 5ft Ht $150.00
TOTAL $54,650.00
I would also like to check out the PE(Professional engineer) fees for my 3/4 windows as i am changing them.
My I/D quoted me (PE submission fees for window - $2300.00). please advise on this too Thanks!
Edited by CuTeDuDe
Hi all,
Thanks!.
at balcony beam
B MASONRY WORK
a Kitchen $1,200.00
a Kitchen $150.00
1 To supply & construct false ceiling ****, dining hall and passage way $1,400.00
and light cove **** hall
D DOOR WORK
d Bedroom 2 $520.00
e Bedroom 3 $580.00
E CARPENTRY WORK
KITCHEN
Bathrooms
TOTAL $54,650.00
Hi CuTeDuDe,
First of all. Welcome to Renotalk.
I would say the quote is reasonable.
Happy Renovation!
Cheers,
Jaskel
