amazone
Electric Trip
hi all,
possible to advise should i upgrade my mcb voltage as if i open my storage heater for more then 5 mins my whole house will trip, n when i switch back on the main mcb i cant on aircon etc as it will trip the whole house again. anyone happens to have the same symptoms?
hi all,
you might have overload your whole house.... too many items using electrical. you might want to get an electrician to come and check?
that was my concern when i was rewiring. old hdb only 30Amps and you have to calculate all electrical items you have at home and add their voltages together.
hi mine is a new flat in punngol worst this is i only on the heater, ceiling fan and aircon. possible hdb provided an faulty MCB switch?
Its better to get an electrian to double check I m sure somthing wrong with your wiring as its new estate
Hope u able to settle it asap :yamseng:
hi all,
Don't wait.....call an electrician now to check.
