pixyish
Brick Wall For Living Room
I want to achieve brick wall look for one of my wall in the living room (7100mm). Went to one of the ID and he quote me appx $7000 for that 7100mm wall. I thought it may cost 2K-3K. =/
I have no confidence in DIY as well as I read a few that some bricks may fall. so i wanna leave it to the experienced in the industry. But 7K is really overpriced and I am really on a tight budget.
If you or anyone have a better quote, kindly reply/ pm me to share pls! Thank you!
If you are using Craft Brick (which is insanely expensive in Singapore as one can get the same thing just across the causeway for 1/4 the price), that required expensive labor to lay, generally it will set you back between $16-$20 psf, you can consider using Stucco Wall to achieve a similar brick wall effect. Check it out with my ID (in my signature), he should be able to quote you a good price.
Thank you for sharing! Will read your blog soonest!
  • Like 1
