MelanieTan
Is This Quotation Reasonable? Imo Seems Okay But I'm A Noob
Hey guys,
This is a direct copy and paste no-nonsense quote (which i LOVE).
I do find that their cement base is a little high, and so are their power points. But... not too sure about the rest, especially kompactop. Any kompactop home owners PLEASE ADVICE!
QUOTATION FOR RENOVATION WORKS
S/N Work Description Unit Price Qty Amount
1 Living Hall/ Dining Hall
a. Hacking of existing 1pc of L-shaped full height wall $600- 1set $600.00
b. Supply labour and materials to do touch up of affected area in cement screed finish $500- 1set $500.00
2 Kitchen
a. Design and fabricate 11ft top and bottom kitchen cabinet in selected laminate finish and internal white PVC Finishing $220- 11ft $2,420.00
b. To supply and install 11 feet Kompactplus $140- 11ft $1,540.00
c. To supply and install colored tempered glass backsplash in kitchen. $34/sft- 30sft $1,020.00
d. Supply labour and materials to construct cement mortar base
Kitchen Cabinet $350- 1set $350.00
Washing Machine $150- 1set $150.00
Fridge $150- 1set $150.00
3 Others
a. To supply and install window grill **** room. 1set $476.00 Total 68sqft
b. To supply and install window grill at Bedroom 2. 1set $238.00 Total 34sqft
c. To supply and install window grill at Bedroom 3. 1set $238.00 Total 34sqft
d. To supply and install window grill at Master Bedroom. 1set $252.00 Total 36sqft
e. To supply and install window grill at kitchen. 1set $252.00 Total 36sqft
f. To supply and install sliding window at balcony. 1set $432.00 Total 36sqft
4 Plumbing
Supply labour to install 1 x handspray to MBR & Common bathroom $50- 2set $100.00
Supply labour to install 1 set of bathroom accessories each at MBR & Common bathroom $50- 2set $100.00
Supply labour to install kitchen sink c/w inlet & outlet piping at kitchen area $90- 1set $90.00
Supply labour to install water storage heater $120- 1set $120.00
Supply labour to connect washing machine inlet & outlet piping at kitchen area $90- 1set $90.00
Supply labour to install basin at MBR & Common bathroom $80- 2set $160.00
Supply labour to install tap, inlet and outlet piping at MBR & Common bathroom $90- 2set $180.00
5 Electrical Works
Installation of Light $15/Light TBA
Installation of Ceiling Fans $45/Fan TBA
Installation of DownLight w/ Wiring Works $30/Light TBA
Installation of Cove Lights w/ Wiring Works $30/Point TBA
Wiring & Installation w/ Partial Conceal SCV & Data Point $100/Point TBA
Hacking of Wall & Concealing for Concealed Wiring $100/meter TBA
Installation of Concealed Points, Switches or Power Points $100/Point TBA
Wiring & Installation Exposed Point, Switches or Power Point $50/Point TBA
b. Painting works in Nippon Vinilex 5000 (2 Coating) Max 4 Color $1,300- 1set $1,300.00
c. Protection of Flooring $250- 1set $250.00
d. General Cleaning after renovation $250- 1set $250.00
e. Haulage, clearing of debris upon completion of renovation $550- 1set $550.00
f. HDB Renovation Permit $250- 1set $250.00
Total Amount $12,058.00
(Quoted for inside white PVC & outside mid range laminate based on $50/pc
Cabinets & Wardrobes in Plywood, Incl. of Soft Closing Hinges & Ball Bearing Drawer Slides All Doors With ABS Trimming
No Other Hidden Cost Unless Adding Item)
TBH - I have no idea what the **** is "install 1 set of bathroom accessories each at MBR & Common bathroom" or what is "ABS trimming" plus i read that colour laminate is better?. And a few other quotes are probably unnecessary unless I plan to change the location of the sinks or what... at least thats what i gather. So minus here minus there probably still around 10-11k. PLUS electricity is like 15k? Which is actually around my budget range.
Not too sure if I'm overlooking or underlooking. So for all you pro ppl out there please please let me know where I can nego and what am I missing
Thanks so very very much. I will be on here pretty often as my house is coming soon. The building company said around Feb-Mar 2015.
Appreciate much!
Melanie
I just took a quick look and compare with mine. some of your items is higher than mine. example like the cement base for kitchen etc, I was quoted 450 for the 3 items but yours is 650. secondly, your painting seems like is a limited choices, can only choose vinilex paint, cannot choose odourless or others cause I can choose the whole range and is still at 1300. Installation of light for mine is quoted 10 dollar each.
Hi Melanie,
Can share your contractor detail as need a big major overhaul for my 4rm resale flat.
Hope you can PM at your earliest.
Tomorrow till weekend need to meet all the Contractor.
Hey guys,
2 Kitchen
3 Others
4 Plumbing
5 Electrical Works
Appreciate much!
Melanie
Hey Randy, yea I heard that the adding of additional power outlets in the house is WAY too high. My mom says she can get it for $50 per point, mine's like a 100... thanks for your feedback! will try to nego those items with them
