bikermeow
Sharing My Renovation Experience
Thought I share with all my renovation experience. It can be a dream or nightmare.
The most important thing in getting a contractor is a proven track record. I had a builder who I knew from previously, and hence that was not a problem. I also had a designer who came with a carpenter. They were new to me and unfortunately that did not turn out so well.
It is important to take an interest in your renovations. While this may seem obvious, what I meant is that the onus is on you to do your own independent research. Invariably, contractors and designers will likely give you the options that are easier for them, with less work and maximising of profits. It is up to you to educate yourself on the options available by reading up.
I was fortunate in that I have a friend who was a contractor that gave me advice. Forums like Renotalk also help. I will share my tips as and when I can compose and post.
All in all, the process can be enjoyable or horrible. Here's pictures of the before and after of my living room.
