JL12
Pls Help! Is It Reasonable?
1 Supply labour and materials to hack off half height wall between kitchen and living room $450.00
2 Supply labour and materials to make good damages area after hacking $680.00
(**Tiles to be provided by owner)
3 Supply labour and materials to construct 50mm kitchen cabinet base $320.00
4 Supply labour and materials to construct 50mm fridge base $150.00
5 Supply labour and materials to construct 50mm washing machine base $150.00
6 Design, fabricate and install 16ft kitchen bottom cabinet using plywood complete with $2,240.00
-Laminate materials
-45* degree handle with ABS trimming
-Internal coloured PVC carcass
-Soft closing hinges
-3 x drawers
-1 x cutlery tray
7 Design, fabricate and install 3ft kitchen top cabinet using plywood complete with $540.00
-Laminate materials
-Dish drainer rack
-1 x frost glass with aluminium handle
8 Design, fabricate and install a 6ft kitchen tall unit using plywood complete with $960.00
-Laminate materials
9 Supply labour to run additional 1 no of heater switch for build in oven $160.00 10 Supply labour to run additional 1 no of single socket for portable microwave $75.00 11 Design, fabricate and install L1500mm x D400mm breakfast top using plywood complete with $580.00
-Laminate materials
12 Supply labour and materials to install 16ft quartz table top complete with a backsplash $2,240.00
13 Supply labour to install 10mm tempered fixed clear glass panel at half height wall(est. 28sqft) $985.00
14 Supply labour and materials to install 10mm tempered glass door for kitchen entrance $680.00
15 Supply labour to connect water outlet for washing machine FOC
16 Supply labour to install cooker hood and hob FOC
17 Supply labour to relocate and recommission 1 no of double socket above stove $90.00
18 Supply labour to run additional 1 no of heater switch for cooker hood $160.00
19 Supply labour to install sink with tap FOC
20 Supply labour to run and connect sink inlet/outlet piping FOC
B Living room works
1 Supply labour and materials to construct 6ft feature wall using partition board $650.00 2 Design, fabricate and install 6ft tv console using plywood complete with $1,080.00
-Laminate materials
-45*degree handle with ABS trimming
3 Supply labour to relocate and recommission existing tv area:
-1 x double socket $90.00
-1 x scv point $160.00
-1 x datapoint $240.00
C Master bedroom works
1 Design, fabricate and install 6ft sliding door wardrobe using plywood complete with $1,860.00
-Laminate materials
-3 x drawers
D Master bathroom works
1 Supply labour to construct 50mm shower kerb complete with full tiles $150.00 2 Supply labour and materials to install 10mm tempered glass door complete with 1 fixed 1 swing $460.00
E Ceiling/Electrical works
1 Supply labour and materials to construct false ceiling L-box without cove light **** room $1,350.00 2 Supply labour and materials to run 11 x PLC lighting point $935.00
F Plumbering Works
(Master/Common bathroom)
1 Supply labour to install and connect: FOC
-2 set of mirror
-2 set of toilet accessories
2 Supply labour to run and connect piping for storage heater tank with installation $150.00 3 Supply labour to run new point for 2 nos of bidet spray with installation FOC
G Misc works
1 Supply labour and materials to paint the whole house using nippon paint vinilex S5000 ceiling using white $1,100.00
Up to 5 colours
2 Supply labour and materials to provide chemical washing upon completion FOC
3 Supply labour and materials to provide general cleaning upon completion FOC
TOTAL AMOUNT: $19k
Edited by JL12
  • Like 1
