terenc3le3
Old Hdb Aircon Cut-Up Hole
Hi Guys
My resale MBR aircon CU area, the big hole covered by plywood is now beginning to leak water (had already partially spoilt my laminated flooring actually). I've consulted HDB and they say I cannot use bricks/concrete to cover the area as they are afraid that "its too heavy". Nvm that, but they suggested to use aluminum sheet to cover the area and can last for years.
Anyone using this method can show some picture on how would it look like? Also, will it be a better noise insulated compared to plywood? Thanks!
My aircon contractor cover the outside with Aluminum sheet and inside using plywood.
Outside.. I cannot show you unless I climb out.
Inside .. it already paint over.
move in since 2010, so far so good.
