Bubbasan
How To Remove Decking/deckboards On Planter Box?
Hi does anyone have any ideas on how one would remove the decking/deckboards that has been installed on/above a planter-box? Would like to clean the area beneath the decking, i.e. the planter box.
I do realise that once I remove 1 board, the others are going to be easily removed, but the problem is getting that first deckboard out since the decking is tightly packed together.
Had 2 ideas:
1. Use a crowbar - but that might damage the surrounding decking/deckboard pieces and it may be difficult to squeeze the crowbar through the little gap present in between the boards.
2. Use some sort of suction device - this seems like the best option but I have not come across such a tool.
*Cutting/sawing the board is not an option since I would still like to use the board(s), just want to remove them to do cleaning.
Suggestions anyone?
