jimmya
Is This Quote Cheap And Reasonable?
On 7/26/2015 at 2:05 PM, jimmya said:
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi Jimmya, can i have the contact of your ID as well? Thank you!
