soulsoul
Quote Review For 1St Time Bto
  1. Design Works
    1. Design consultation & space planning
    2. Design proposal & 3D perspective drawing
    3. Selection of colour, material & accessories
    4. Consultant & project management
    5. Site inspection / work schedule
  1. Masonrv Works
    1. Supply & lay cement Pre-Pack cement screeding for living/dining & all bedrooms
    2. Supply & lay 600mm x 600mm homogeneous floor tiles for living / dining & all bedrooms
    3. Laying of glossy homogeneous skirting for living/dining & all bedrooms
    4. Construct 50mm kitchen cabinet base c/w side tiling
    5. Construct 50mm fridge & washing machine bases c/w full tiling
  1. Plumbing works
    1. Supply & lay concealed 2" drainage pipe for kitchen sink & washing machine
    2. Extension of copper piping to new kitchen sink position
    3. Labour to install 1 set of storage heater / 2 set of bathrooms accessories & mirror / 1 set of Kitchen sink & tap
  1. Ceiling Works
    1. Construct L-Box light holder for living & dining hall
    2. Construct false ceiling for foyer area & bedroom passageway
  1. Carpentry works
Kitchen
  1. Design, fabricate & install 20ft(L) designer kitchen cabinet in solid-ply high grade laminate finish
    • ABS Trimmings doors & handles
    • Inos of frosted glass panel c/w wooden frame
    • Ino.s of 2 tier stainless steel dish drainer & 1 no.s of cutlery tray
Solid Surface Works
  1. Custom made 10ft(L) solid surface worktop c/w 50mm backsplash & front profile
  1. Painting Works
    1. Painting of whole unit internal walls & ceiling with ICI Pentalite/ NIPPON Emulsion paint
    2. Painting of all pipes, door frames & gate with ICI/ NIPPON gloss pain
  1. Miscellaneous Works
    1. Chemical washing upon completion of works
    2. Provide corrugated paper for protection
Package is $21188
Partition Works
Living
Supply & labor to construct double side partition wall with gypsum board
148 sqft
$ 740
Glass Works
Kitchen
Supply & labor to install 6mm thk kitchen temperd glass backing> < 11 a w x 20 h)
11 ft
$ 770
Another side
$ 700
Dining
Supply & labor to install 6mm thk (clear/tinted) mirror for dining>(6 ft w x 4 ft h)
24 ft
$ 480
Master bathroom
Supply & install 1 set 1 Omm thk tempered shower panel>< 3ft w x 7ft h )
21 sqft
$ 240
Full shower and door
$ 250
Masonry Works (Inclusive of wastage)
Master bathroom
Supply and labour shower kerb for shower panel
1.3 ft
$ 150
Additional full shower
$ 70
Aluminum Works
Supply & labour to install aluminum sliding window for service yard
40 sqft
$ 550
Door Works
Supply & labour to install a SEMI-CORE Classic Door with'frame for studdy room 1 no.
1 no
$ 250
Supply & labour to install swing slide door (Acrylic + Glass Design) for kitchen entrance i no".
1 no
$ 580
Sliding Door
$ 150
Carpentry Works (Subject to changes) All Internal carcass in white PVC finish
Living
Design & fabricate shoes cabinet in solid-ply high guide laminate
1.3 ft with full Ht
$ 840
Design & fabricate furture wall in solid-ply high grade laminate for cover up shelter with 1 door
1.3 ft with full Ht
$ 750
Dining
Design & fabricate setee in solid-ply high grade laminate
1.6ft
$ 780
Kitchen
Design & fabricate tall unit in solid-ply high grade laminates.
1.2 ft with full Ht
$ 780
Design & fabricate top kitchen cabinet in solid-ply high grade laminates.
L 10 ft
$ 1,300
Design & fabricate bottom kitchen cabinet in solid-ply high grade laminates.
L 7 ft
$ 910
Supply & install quartz at kitchen work top L 6 ft
L 7 ft
$ 700
Master room
Design & fabricate 8 lit laminaled sliding wardrobe in solid-ply high grade laminate
L 8 ft
$ 2,160
Full Ht
$ 320
Design & fabricate suspended study and dressing table in solid-ply high grade
L 6 ft
$ 840
Design & fabricate suspended tv console in solid-ply high grade laminate
L 4 ft
$ 560
Design & fabricate quees size bedframes in solid-ply high grade laminate
1 no.
$ 900
Design & fabricate bedside table in solid-ply high grade laminate L 8 ft L 6 ft L 4ft
2 no.
$ 500
Bedroom 2
Design & fabricate 8 ht laminaled sliding wardrobe in solid-ply high grade laminate
L 5 ft
$ 1,350
wardrobe for Bedroom 3
$ 1,350
Top floor
$ 400
Bathroom
Design & fabricate mirror cabinet stroge in solid-ply high grade laminate
3 ft
$ 450
Master room / Vinyl Flooring
Supply & labour lo lay HIGH RESILIENT VINYL flooring( top- up S3 per sqft) Bedroom 2 & 3 / Vinklv Floorinp
191 sqft
$ 573
Bedroom 2 & 3 / Vinyl Flooring
Supply & labour to lay HIGH RESILIENT VINYL flooring( top- up $3 per sqft)
292 sqft
$ 876
Edited by soulsoul
