adrianpoon
Need advice on quotation
Hi All,
I need sincere advice on a quotation that I have received from an ID. Not sure if the price is reasonable.
Personally, I feel that the false ceiling and some carpentry work is on a high side.
Your advice is much appreciated.
Thanks alot in advance.
Ceiling
Living/Dinning
Supply & install false ceiling (150mm drop from original ceiling) - $550
light box c/w T5 pelmet (04 inner sides) - $680
curtain pelmet (01 unit) - $180
Lighting recess pelmet (01 unit) - $450
aircon pelmet (02 units) - $80
Total: $1940
MBR
Supply & install false ceiling (150mm drop from original ceiling) - $950
curtain pelmet (01 unit) - $100
Lighting recess pelmet (01 unit) - $180
Aircon pelmet (01) - $80
Total: $1310
Bedroom 1
Supply & install false ceiling (150mm drop from original ceiling) - $650
Total: $830
Bedroom 2
Total: $830
Total for Ceiling - $4910 :blink:
Carpentry
Living/Dinning
Fabricate & install storage cabinets c/w open display shelf (2400mm (L) 450mm (W) 2400mm (H) ) - $2400
Fabricate & install TV feature wall c/w display cabinet (02 units) (2400mm (L) 100mm (W) 2400mm (H) ) - $2100
Fabricate & install suspended TV console (2400mm (L) 450mm (W) 300mm (H) ) - $1100
MBR
Fabricate & install storage bed c/w hydraulic life system (King size)(1800mm (L) 1900mm (W) TBC (H) ) - $1450
Fabricate & install headboard (4000mm (L) 100mm (W) 1200mm (H) ) - $1550
Fabricate & install designer panels c/w matte white finishing (02 panels) (4000mm (L) 100mm (W) 1200mm (H) ) - $2350
Fabricate & install side tables (02 units) (2200mm (L) 250mm (W) 50mm (H) ) - $700
Farbricate & install TV ledge (2900mm (L) 150mm (W) 50mm (H) ) c/w metal inserts for strength - $700
Total for Carpentry: $12,350
General Works
Supply labor to repaint whole apartment (walls & ceilings) with water based sealer coat (01) - $450
Supply labor to repaint whole apartment (walls & ceilings) with NIPPON EasyWash Paint - $1750
Basic floor protection - FOC
General cleaning upon completion of all works - FOC
Grand Total: $19,460 :bangwall:
ceiling really depends how big is your living and rooms, the price still ok .. just expensive by abit ..
Carpentry definitely expensive.. remember to ask if it's internal color and what hinges ? BLUM?
Thanks. need to clarify more things with this ID. alot of things never specify (eg. false ceiling size.)
overall, think the general feedback that I got is that my quote is quite expensive.
Thanks
