MyDigitalLock1
S series Nikawa Fire Resistance Safe with 120db alarm HP: 92220659
Nikawa Evolve Designer Safe S series
Features
A touch screen keypad that lights up upon touch. Can activate stealth mode for silent unlocking
User Pin –  2 user of 4-20 digits
Keypad lockdown for 3 minutes after 5 wrong pin entry. The alarm will also sound off.
Low Battery Indicator
Emergency power up using Micro 2.0 USB port
5 x Dia 19mm locking Bolt (3 live, 2 fixed)
Inbuilt with 120 decibel alarm that has a tilt sensor
Allow bolting to the base
Modern design without electronic front to blend into interior design and support camouflage
KS 1hr fire test
Support auto lock function with motorized motor
Made in Korea
Technical details
External dimension H x W x 😧 536 x 410 x 475mm
Internal dimension H x W x 😧 412 x 305 x 320mm
Net Weight (kg): 63
Volume (litres): 37
Internal shelf: 1
19mm steel locking bolts
Use 4 x AA (1.5V R06)
Certificates
Tested to withstand up to one hour intense fire
Internal temperature will not exceed 150 Degree Celsius in 927 Degree Celsius furnace
Certified by KS (Korea Standard)
📱: 92220659 (PAUL)
Order Now and get it today 92220659
*****9th Ang Mo Kio Hub(North East)******
Basement 2 B2-14
Hp 92220659
Hp  8718 8880
Hp 98811733
HP 96177025
HP 88668884
Office: 91616282 / 85957577
Office:  90677990 / 88140503
