Lerlaine
Plastering Of 3 Room Wall & Painting Over Dark Colour
Hi
Can anyone advise roughly what is the cost of plastering the living room of an old 3 room flat?
Also, any tips on painting over dark pink, dark green and bright yellow walls? Does primer work better than painting a few layers?
Am still considering if i should do DIY painting or to engage painter, coz the current dark colour might be a challenge to paint.
Thanks!
  • Like 1
to paint over, use a couple of base coats, before applying another 2 layers of color. time consuming, as you need to wait for each coat to dry for long lasting effect.
Hi Getzski
Thanks for your advice. (:
May i know if there is any difference between base coat and primer?
Painting is tedious. But you can save at least 1/2 of the money. I did mine. 4 room flat. 104sqm.
1. Re-seal/prime if some old paint peel off. Prefer Oil sealer. 4-6 hours apart before the actual paint. Seal to avoid water coming in.
2. Base coat/White Emulsion if your old coat is dark color. (Dark blue/Dark Red). Skip if old paint is light color.
3. At least Two coat of paint. 4 hours apart each. (Assume you buy nippon/dulux). Prefer a day apart. Excuses for rest :) Enjoy, not overwork.
Paper Tape all corner. Buy a big plastic sheet from SK to cover the entire floor from drips. Cover all equipments.
Paint roller. Brush.
Buy 1 litre to try out the color before you go ahead for the 5L. (Always tell your paint store it is for wall. Metal/wood uses different kind of paint. Gloss)
thanks Donfan! Its helpful at least i know what to take note. (:
