kayone 0 Report post Posted October 30, 2014 I am in the middle of my home renovation activities and still looking for some new ideas and inspirations. Found this article quite interesting if your current project is the bedroom:How to Illuminate a BedroomYour bedroom serves you in multiple purposes than merely being available for slumber. Whether it is the magnificent master bedroom or a smaller one, over in attic or in a yacht, your want it to be the luxurious place you can retreat to.The designer lighting ideas from antique sconces to contemporary pendants helps you achieve the dreamy affect in that space. From bold to dimmed, in order to properly light your room without affecting the different activities, you need to consider the following factors. Note down the room’s measurements – the size and height – since you do not want lighting that is out of its alignment. Fixtures with longer bodies should be avoided while shopping since they reduce the space that their light is supposed to reach.Where the occupants’ interest in vanities would lead them to have a brighter place, the place assigned for sitting seeming to be more appropriate for shaded and softer fixtures, actions like studying or sewing require more directed lighting. From nurseries to a senior citizen’s bedroom, each has their individual need for the lighting to conform to. Install them in all the right places to get the right sort of ambience. For example, a bedroom should have an overhead light but not one that is uncomfortably directly above the bed. Plus, with the types of portable lamps available, lighting can become a sort of visual comfort and pleasure with all that flexibility and adjustments as well as the possibility to use light sources of lower wattage.Another factor that you should focus upon for the bedroom is the installation of dimmers to manage the mood settings for your place. Colored or softer light can be preferred then. If it’s a reading light, consider the fact that they are well-shielded and their controls located around the centre of the headboard so you can turn them off without disturbing your partner. You can also have the high tech controls like an infrared remote to turn on or off the lights in your bedroom. Should I still be purchasing table lamps for my bedroom?Interior-Deluxe: Definitely a yes. They are the best way to illuminate your bedside and give the symmetrical balance to the room. The different styles, sizes, colors that now exist for these lamps can give you a huge variety of options with which you can complement your room in a rather inexpensive, quick face-lift. Make sure they are at the right height though. If you have tables for each side of your bed, you can choose both to be coherent or eclectic. You can select the alternative of a swing arm too with respect to the standard lamps.If, however, you do not find them a remarkable sight or wish to redesign the space use, you can opt for the wall-mounted sconces. You do not have to worry about the light being in your eye or not being suitable for task lighting because their hinged fixtures can be adjusted to direct the light exactly where you want it. They are adaptable for use in every bedroom; their designs from the modern to decorative classic enhancing the romantic feel.The latest style guide, however, marks bedside pendants as one trend for the sleek and modern look. They are a perfect eye-catcher in their difference of being a ceiling-mounted option and the way they can be put on a dimmer. Most of the time, however, they are used simply for attraction in the overall ambience with no real purpose of illumination.Read on at http://www.interior-deluxe.com Share this post Link to post Share on other sites
