nimmy
False Ceiling
Hi everyone,
We bought a 4-room resale flat ( 85sqm) ard Hougang area.Its nicely renovated except for false ceiling.
We r planning to have a false ceiling for the hall area.Hall has an L-shape because of bomb shelter fitting into the hall.Dnt have any idea of types of false ceiling and price ranges.Can anyone please advise on this matter?
Thanks
Hi everyone,
Thanks
false ceilings - can generally be categorised into
1) true false ceiling - almost the entire ceiling is 'fake'
- it will usually cost about $800-1000 to do up false ceiling for 5rm living and dining excluding lighting and electricity of course
- about another $400-700 for master bedroom
2) L box - usually built around the perimeter of the living room hall. L box will of course be cheaper cos less material used. there are modifications some contractors do to make L box nicer, e.g. make an underhang, etc.
- usually about 30% cheaper than true false ceiling
height of false ceiling
- 4 or 6 inches thick
- while 4 inches is better in a sense that it doesn't 'shorten' your ceiling by so much, your lighting choices are very restricted (since shorter height)
- do take note that HDB has a height restriction - the min floor to ceiling height is 240cm, and most hdb flats are 259cm height, so if you have a 4inch platform anywhere in your flat, you may not be able to install a 6inch false ceiling there
types of lighting that can be used in false ceiling
- downlights - can be halogen, energy saving, daylight, warmlight
- long fluorescent lights - can be installed above the 'underhangs' to create 'hidden lighting' effect (but can trap dust/dirt/insects!)
ceiling fan
- not advisable to install ceiling fan on false ceiling, unless you don't value your head/hair
- also structurally not sound
- if you want ceiling fan, then better to install L box so your fan can be installed in the middle on the 'real ceiling'
hope this helps!
Edited by purpledino
