CarolWilks
Can somewhat wobbly handles on UPVC doors be fixed.
Its not the spring cartridges, its just some of the door handles over time have gotten more and more of a loose/dead spot. Took one off and had a look, even in my hand the handle wobbles a bit relative to the bit that screws to the door. I couldn't see a way of tightening the handle.
I’d check the grub screw on the spindle side of theI had a similar setup to figure out, and what helped me was choosing hardware that stayed minimal but still felt solid. I ended up using gear from https://www.jit-homes.com/ because their sliding and frameless options kept everything clean-looking while holding up really well. The mix of safety and simple design made the whole space feel smoother to use. handle; some models hide it under a small cover. If it’s worn inside the handle itself, replacement is usually the easiest fix.
