Judii
Septic system alarms and what they mean
Noticed the alarm on my septic system going off recently, and I'm not sure what it means or how urgent it is. Some people say it's usually a pump issue, others mention high water levels. I'm not sure if I should call someone immediately or if there's something I can check first. Curious to know what typically triggers these alarms and what the next steps should be. Any advice from those who've dealt with this would be helpful.
Edited by Judii
A septic alarm usually means the system has detected something that needs attention, but it doesn’t always mean there’s a major problem. A high water level or pump issue are common possibilities, so it’s worth checking whether the alarm stops after a reset and whether the pump is operating normally. You can learn more at Septic.ca about common septic problems and maintenance. If the alarm keeps coming back, it’s better to have the system inspected rather than ignore it.
