CutePinkElephant
How To Read A Compass
These days still got use compass meh? Many ppl use watches which have electronic compass, others use GPS liao.
Anyway.. cheap or expensive compass all work the same. If it works, it works. Expensive ones simply means more durable, it will work all the time. Cheap ones maybe knock a bit, stop spinning liao. Good ones got better magnetic insulation so that small metal objects nearby dun interfere with magnetic north. Beach Road market selling army things got many compass selection.
i use the compass for checking main door position, related to fs, can ask the fsm to use GPS me?wahuahwuawhauw
thanks anyway ;)
thanks anyway ;)
go to those sports wear/goods shops and get one.
then go to those $2 dollar shops and get your second one.
use 2 to compare the readings.
when taking readings, stand at the position that you want, then take a step forward + backward to check whether there are any metal affecting your compass reading. some old houses's super hard/thick metal door frame is heavily magnetized!
:bangwall::bangwall::bangwall: until now i havent success reading for my main door exact degree arghhhhhhhhhhhhh... :bangwall::bangwall::bangwall::bangwall:
- Main door :NE 47degree
- 3step back from main door : NE 37degree
- Most window : NE 32degree
- Center of the house : NE 35degree
the main door degree is so far away from other :dunno::dunno: maybe the gate hor..?
this time i take a reading must open the metal gate, take off watch, ring,belt liao :notti:
