priyalok
Precaution With Laminate Flooring
I am planning for laminate flooring in my bedrooms.
As I must take care not to spill water, just curious how to protect:
- area near toilet
- area near windows - must close window all times when going out in case it rains?
Yes, make it a habit. In fact, I even close the windows of my kitchen, utility room & living room when I go out though laminated flooring is only installed in the bedrooms.
ur perfectly right.
what about area near toilet door?
any special door mat?
ur perfectly right.
This one I can't comment cos I have no master bedroom toilet :P
I reckon making a kerb outside the toilet will help. Also, a mat with rubber layer at the bottom is better, so that water will not sip thru & go into the laminated flooring. Just my common sense thinking :lol:
How do u clean and maintain supremem laminate floor? COntractor told me use cleaning agent for wood/parquet. My mum said just use very dry mop. Beats me.. any advise?? thanks.
Which one do you want to know? Wood/parquet or laminated? They are different.
For laminated flooring, just use very dry mop with plain water is good enough. But I am a bit kiasu, I use Sofix once a month to make my floor feels smoother.
The kerb is a good idea. But a rubber mat will actually trap water beneath it if you're not careful, so best to use carpet rug instead. :)
Best way to maintain laminate and wooden floors is to damp mop with water (wring tightly first) once, then dry mop again. The cleaning agent can be used once a week, depending on your level of traffic.
Cheers.
