lushbelle
Pls Advise On My Reno Quotation
Hi guys, please help me see if this quote is expensive or not.
HDB 4rm abt 106sqm
I have supply of tiles so all is based on labour only.
And the ID never breakdown the individual prices they just give me the lump sum.
1Hack & dispose off existing floor tiles at :-
- 3 bedrooms- living- Kitchen- Master toilet- Common toilet
2Hack & dispose off existing wall tiles at - Kitchen- Master Toilet- Common Toilet
3Dismantle all unwanted cabinets & fixtures
4Dismantle existing L box
5Dismantle existing toilet bowls & basins
6Hack a portion of wall at between living & kitchen and plaster smooth
B1Floor tiles
1SUPPLY LABOUR ONLY to lay floor tiles **** & store- includes skirting
2Supply labour & materials to lay cement screeding for 3 bedrooms
3Supply labour & materials to lay short-strip parquet for 3 bedrooms- includes skirting
- Burmese parquet
4Supply labour to lay floor tiles at kitchen- includes water-proofing
5Supply labour to lay floor tiles at master toilet- including water-proofing
6Supply labour & materials to lay floor tiles at common toilet- including water-proofing
B2Wall tiles
1Supply labour to lay tiles at kitchen- to full ceiling height
2Supply labour to lay tiles at master toilet- to full ceiling height
3Supply labour to lay wall tiles at common toilet- to full ceiling height
C1To construct 50mm height kitchen cabinet base
2To construct 50mm height fridge base with tiles surface
3To construct 50mm height w/machine base with tiles surface
4Construct 50mm height shower kerb at master toilet
PLUMBING & SANITARY
1To replace whole house s/steel pipings ( cold )
2To extend sink & w/machine in/outlet
3To connect sink & w/machine in/outlet
4To install 2 x toilet bowls & basins ( Labour only )
5Supply labour to install bathroom accessories & heater
Whole house painting
WHOLE HOUSE LAYING OF CARDBOARD
ACID-WASHING
ECARPENTRY WORK
1To design, construct & install shoe cabinets using laminates finish 4Ft
2To design, construct & install built-in wardrobes using laminates 7Ft
3To design, construct & install built-in kitchen cabinets using laminates 20Ft
-supply & install s/steel dish-drainer
-supply & install 1 no. of cultery tray
-supply & install 1 set of drawers ( BLUM System )
-supply & install solid surface top ( 10 ft )
To install sink, cooker hood & hob ( Labour only )
TOTAL $28k
Edited by lushbelle
The previous quote the ID never list down all the breakdown so i really dont know if it's of a reasonable quote.
What about this quote from another ID?
What other items have I miss out?
Can advise me please. Thanks
HACKING
1. Old tiles for the entire house. (living/3rooms/kitchen/kitchen walls/2 bathroomwalls) $2,600
2. Hacking a wall from the kitchen to living room (around 4ft) $300
3. Hacking away the L-box ceiling $160 per foot run (u didnt state is for living only or whole unit)
4. Remove the kitchen cabinent $250
FLOORING
5. Laying tiles for living/kitchen/2bathrooms (labour charge only) $1280
6. Laying Lacquer Parquet Wood Flooring (3 bedrooms) $3,000
7. Cement screeding before doing parquet flooring $1,050 - 3rooms
8. Relay toilet tiles (labour only) -2 toilets $1,100 (
9. labour for WALL tiles of 2 bathrooms $1100
10.Water proofing grout for kitchen & 2 bathrooms) $700
ELECTRICAL
11. Rewiring the whole house powerpoint and SCV point estimated abt $3,200
MASONRY WORKS
12. Construct kitchen/fridge/washing machine base $300
13. Build a showerscreen kerb 2 Bathroom $300
CARPENTRY WORKS
14.20ft top & bottom cabinets with anti-slam hinges, 1no dish drainer & stainless steel backing at hob area ONLY $2780
15. Shoe Cabinent (aprox 3.5ft x 6.5ft) $780
16. Walk in Wardrobe (full height x 6.5ft) $1,780 (normal sliding door wardrobe with laminate finish)
PAINTING
17. painting for walls $1,300
18. painting for 5doors $150
They shld list down the breakdown. If they don't then move on.
For kitchen, not sure 20ft enough. usually 20 ft cannot make it. So you will need to factor additional costs per foot run, usually $110. If you require tall cabinets (floor to ceiling), it's a different cost. If you require lots of carpentry in the kitchen then maybe you shld do away with wall tiles. Save $$ and not really necessary. Plaster and paint is enough. For the cooking area you can always install lacobel glass backing at price is around $30/pfr.
For carpentry (wardrobe, shoe cabinet), general price is $240 pfr. So if cabinet is 7ft the cost is $1680. For wardrobes etc, pls note that it's the length of the cabinet. So, 7ft all the way up to ceiling is still $240/pfr.
Solid surface (normal not the super ex brands) is arnd $90pfr. Post form is arnd $40-$50 pfr.
Good luck.
I may be wrong but cement screeding for bedrooms is FOC by HDB. At least it was for mine as it was a new unit. :dunno:
hi JCase,
noticed that u haf engaged *****.. hw is their pricing and service?
haf u started the reno works aldy? i am looking for a reasonable pricing company to assist with my renovation. Any recommendation on ur current ID or renvation company?
pls email me... priscillatoh@hotmail.com
