simon7c
Biowashball - Washing Clothes Without Detergent?
Anybody tried it before? Not sure if it really does what it claims.... :dunno:
Biowashball
EnviroGadget.com
Wash your clothes without detergent with the Biowashball. This small revolutionary product will save you thousands of dollars a year! And it also helps preserve the environment! Biowashball is your alternative to detergent.
Biowashball is a unique product designed to clean clothes without the use of harmful detergents. You simply do not need to buy detergent ever again!
Just place the biowashball in any washing machine, set on cold or hot cycle, and your clothes will come out clean and fresh every time.
Biowashball eliminates allergic reactions linked to detergents with artificial chemicals. Its pattented technology eliminates germs and bacterias which produce unwanted odors. Detergents only mask these smells with fragrances. The Biowashball destroys them!
During the wash cycle, the combination of the ceramics in the Biowashball alter the water's PH value. This causes dirt to be unable to remain on your clothes down to the chemical level. It actually changes the adhesive properties of the dirt. During your rinse cycle, the dirty water is drawn out of the machine and you are left with clean disinfected hypoallergetic clothes. No detergent can do that!
Biowashball is:
- Easy to Use: Just place it inside your washing machine along with your dirty laundry. Biowashball has no side effects caused by detergent residue on your linen.
-Antibacterial: One Biowashball helps eliminate pathogens and other germs found on dirty clothes. Perfect for disinfecting!
-Economical: A Biowashball eliminates the need for detergents. The average person will waste hundreds, if not thousands, of dollars on detergents in just one year. But one Biowashball will last 3 years!
-Ecological: As an added bonus, the Biowashball does not contain phosphates which damage the environment. Not only are you saving money andcleaning your clothes better, but you are also helping mother nature!
-Unique: Dont be fooled by cheap immitations and knock-off products that dont work. Biowashball is the first of its kind.
