anetha
Assessing Contractor Quotation
Dear Friends,
Can you please help me with assessing the following quotation I got from my contractor.
The renovation is for a 3 bedroom unit (1300sq ft.) which is 10 years old now.
Thanks a lot.
Kitchen-Store Room
1.Supply & replace 6 nos. post from door & 3 nos. post from drawer & 1 nos. below oven for existing cabinet 850
2.Provide labor to remove & reinstall new kitchen sink & connection for existing cabinet 120
3.Provide labor to remove & reinstall new cooker hood & hob for existing cabinet 50
4.Alter cabinet to fit hood and replace 2 doors above cooker hood 450
6.Supply & seal up existing Upper cabinet open space using gypsum board finish 350
5.Supply and re-polish existing solid surface kitchen top 380
7.To supply and install powder coated aluminum bi-fold door for store room 170
Living Room
8.Provide marble dry polish for existing hall marble including skirting & entrance areas 580
9.Supply & install 1 nos. wrought iron bar & hook include existing ceiling touch up (for hanging chair) 200
Bed Rooms
10.Hack off existing laminate flooring & cement mortar base for all bedrooms 780
11.Provide labor to remove & reinstall existing 3 nos. build-in wardrobe including touch up & repair work 1750
12.Supply & lay 600mmX600mm polish homogenous tiles including skirting for all bed rooms 4150
13.Provide hand polishing for master bedroom toilet existing marble wall tiles & floor tiles 450
Electrical Work
14.Lay concealed LAN (network) cable 3nos. connecting living room SCV point area to 3 bed rooms 450
15.Lay concealed extra SCV point to living room wall 150
16.Lay concealed 2 nos. LAN(network) cable connecting living room wall 300
17.Replace switches - 17 number 340
18.Install 5 electrical fans 175
19.New fan point installation (1 numbers) in MBR 55
20.Reposition light point for fan installation (2 Bed rooms) 80
21. 7nos. extra double points in living room and 3 bed rooms 700
Painting
22. Furnish whole house wall & ceiling using I.C.I / Nippon 3-in-1 or wash & wear paint 1550
23. Supply & lacquering for existing wooden door & door frames (whole house) 270
Miscellaneous
24. Haulage and clear debris service during renovation work 380
25. Provide lay floor protection covering sheet & thick ply wood sheet during renovation work 250
26. Provide chemical washing & cleaning for all house including window 280
27. Supply & Install cloth lining & wrought iron support 170
28. Repair, touch-up hinges in cabinets + window hinges FOC
Discount 285
Total 15100
Is that your only quotation?
Can't comment much as I did my reno a year ago and chances are pricing could have been changed. So it is better u get more quotations and compare. I believe u should have many other quotation to compare prices with.
Just one comment, from your quote i guessed that u r keeping the kitchen cabinet structure and changing the door and some modifications. But have you consider redoing everything, tearing down and redesign the kitchen cabinet to your taste/liking.
Your total for kitchen store room item 1 to 6 is already 2.2k. Why not get a new one, pfr is about 190 to 260 top and bottom, 10 ft give 1.9k to 2.6k, kitchen top about 700 for 10ft.
So taking 1.9k + 700 = 2.6k for a new one compare to 2.2k old and modified.
Please check with your contractors the price for cabinet.
great suggestion on redoing the kitchen, chronograph - It has gotten me thinking. Thanks!
U r welcome. FYI, should u decide to do a new kitchen cabinet, take note that the installation of sink, hood, stove and oven is free.
Dear Friends,
Thanks a lot.
Kitchen-Store Room
Living Room
Bed Rooms
Electrical Work
Painting
Miscellaneous
Discount 285
Total 15100
The quote looks competitive. I just completed my renovation in mid July.
