xiaofeng123
Simple Reno
hihi...
Need your all opinion about the quotation i just get from contractor recently. After comparing the prices below with the prices from this forum, i think the quotation is quite expensive.
supply & install tempered glass door and door frame at the rear of kitchen - $560
overlay the kitchen flooring - $900
hacking the kitchen cabinet and haulage - $300
design, supply and install top and bottom kitchen cabinet(16ft) - $3500
design, supply and install solid top(14ft) - $1120
design, supply and install TV console(8ft) - $1520
design, supply and install master bedroom sliding wardrode(5ft) - $1560
dismantle and replace the old socket and some electric stuff installation - $1400
Appreciate for you advise and opinion.
hihi...
supply & install tempered glass door and door frame at the rear of kitchen - $560 ( wat type of door frame??)
design, supply and install top and bottom kitchen cabinet(16ft) - $3500 ( top 16ft and bottom 16ft ard $3200, top plus bottom 16ft $1600.)
design, supply and install solid top(14ft) - $1120 ( $1050)
design, supply and install TV console(8ft) - $1520 ( this pricing is for supended console only or with feature wall?? if only console shld be ard $840.)
design, supply and install master bedroom sliding wardrode(5ft) - $1560 ( $1100)
dismantle and replace the old socket and some electric stuff installation - $1400 ( can't give u advise, coz dunno the thing u do n change.)
this is base on the quotation given by my contractor. only a rough guide.
if u r interested i can pm u my contractor nos.
Hope it does help.. :)
Cheers!!
Edited by jadens28
supply & install tempered glass door and door frame at the rear of kitchen - $560 ( wat type of door frame??) - aluminium
design, supply and install top and bottom kitchen cabinet(16ft) - $3500 ( top 16ft and bottom 16ft ard $3200, top plus bottom 16ft $1600.) - reasonable
design, supply and install solid top(14ft) - $1120 ( $1050) -do you know what kind of solid top fo that price? granite?
design, supply and install TV console(8ft) - $1520 ( this pricing is for supended console only or with feature wall?? if only console shld be ard $840.)-with suspended console + feature wall
Hope it does help..
Cheers!!
Thanks for ur advise.
Can you pls send me ur contractor no? Thanks. ;)
Hope it does help..
Cheers!!
hi
pmed u the contact nos. :)
the top will be a solid surface. urs is a granite top?
Just a word of advice, cheap price does not mean good. You might end up alot of troubles. Tried to make sure that the contractor got HDB Licence. It is just an assurance to cover you if any dispute arise.
I agree with u.cheap doesn't mean good.The important things is good service and the the contractor is easy to communicate. My contractor have the HDB license...thanks for advise. :rolleyes:
Firstly, it is important to make sure they at least had HDB License (Having HDB Licnse. Secondly, all payment must be over to the company ID, not through the Contractor pocket. Most renovation Contractors usually run out of cash flow, and they will normally tried to get bits and pieces of job and cover those costs here and there.
A reason for a HDB license or BCA Licence is just to cover yourself in-case of any disputes arises, you can look for the respective authority to persuade into the matter. Do take note, your payment with Contractors must always get a receipt or confirmation either by writing or SMS to you when you started making progressive payment.
