Blanco Metra 9 Sink
Hi
I am having a problem with my Blanco Metra 9 sink, there is water leak from the outlet connection. My contractor came a few times to fix the issue but it always leak after he went back. I suspect he didn't fix all the outlet connection kits correctly. Does anyone using this sink, can snap a photo of the sink outlet connection? Thanks.
This is my sink outlet connection. If you look carefully, you will notice that the ring support on the left is different with the right. I guess this is the reason for the water leak. The plumber should have mixed up the rings. :( Don't know why he came so many times also never spot the mistake.
The above pic shows that the pipe is not permanently seal, he just use masking tape. Is it the normal practise? How should it be?
  • 3 weeks later...
my plumber didnt use muskin tape
I saw him ' white -tape' (many times---seems to me close to half a roll , ) the inner -screw threads b4 fitting the diff pvc parts together,
i think your plu,mber cut wrong length of pvc pipe for the last pic u posted, he ought to install new piece as meant to fit snugly if not will drip i think
& the seams btwm the ppve piipe & floor ought to be filled with white cement-- same type used for tiling
Now the water leak is from the inlet water tube and it only happen once, now ok...don't know what happen... :(
