scorpio2031
Is The Rim Of The Downlight Glued To False Ceiling
Any body pls let me know, what is the right way of fixing the Down lights to L-Box.
My contractor has Glued the Down light to L-box with the White cement or the Plaster of paris(Gypsum).
is that the right way of doing it. or it should be fixed with the screw.
thanks
Normally downlight got a strip of spring like metal plate (with teeth) that clamps the lower rim upwards to the false ceiling. But sometimes false ceiling not perfectly flat so got small gap, so use white sealant to cover gaps. Ideally not use the false ceiling type of paste cos that is not flexible.
