JK_headache
Aircon Casing Turns Yellowish
Maybe you can try painting your walls the same shade as your air-con casing? This will make the aircon casing blend in with the wall and the yellowness will not look so noticeable.
People will even think that it is part of the design! :)
Guest Goobii
Can ... try this ...
from $2 shop @ Daiso ...
White Sponge + Water = Good Cleaning Surface Against Yellowish Aircon Casing
let me try the magic sponge from diaso 1st :)
finally...24th feb is coming.............completion date !
That is the melamine sponge and it is only good for cleaning "attached dirt". The yellowish colouring, is caused by chemical reactions and not some substance attaching to the surface. No amount of scrubbing could remove them. Unless...
