smjas
Remove And Reinstall Of L-box
Is it possible to remove the L-Box and re-install it back if we want to service the electricial cables in future?
I know that small holes can be patch but not sure whether once installed can it be remove and install back.
L-box are attached will only be damaged if removed, and not likely to use back. Why would you want to service your electrical cables which is running along the ceiling edge? Unless you are re-wiring your cables. If there should be any junction box or any other sort of component that you've installed up at the ceiling, I suggest you do up a access panel for that specific position so that you do not need to remove the entire L-box.
