dean
Looking A Vacuum Cum Steam Cleaner?
vacuum cum steam cleaner?
I seen a product call Rainbow, it works as a vacuum and also double up as a air cleaner.
but its costly. around 3k.
looking a vacuum cum steam cleaner? is such product exist? which vacuum is good?
The one i know is rainbow and osim.
Rainbow is expensive but it had very good point that can be use on mattress. I think it is call the mattress beater. So if you want to clean your mattress weekly then it is a worthwhile investment as people are charging 50-100 per visit to clean mattress
As for OSIM, i had one, it is okie, as it is using water filtering system so i can be use the clean the air. The only thing is that it is heavy, if you are not use to it, you will get blister when you first use it. I normally use the stream clean to kill gems but too sure how effective, as there is no way to measure.
Hence, you need to know what is your reason to get a vacuum and stream cleaner then you know what to buy. By the way, i got my OSIM ecology from ebay around 500, which i think the price is good, if you ask me to buy it new, i doubt i will pay for it as > 1000
what brand of stream cleaner u using?
what about philips vacuum?
as i have stated before, i am using OSIM ecology. I am not too sure does Philip have a vacuum and streamer. But i know that they do have a water filter vacuum
