livingonten
Urgent Advice/comments On Our Reno Quote
Hi All!
I'm trying to find out if we've received a reasonable quote for my parents' 5-rm HDB flat. After 20 long years, we decided to do a major overhaul - hacking, plastering, tiling, painting, carpentry and buying that access balcony.
Can someone kindly enlighten us if this reno quote is okay to proceed? We want to redo our entire house, except my brother's bedroom (requires painting, plastering and tiling). But bearing in mind, this $56,100.00 does not include stuff like TV, fridge, aircon, lights, etc, that's why I honestly think it's abit too much. In any case, your advice/comment is greatly appreciated!
Many thanks in advance! :P
A) Hacking, demolish works - $3,500
1 Main entrance wall,door,door frame and gate
2 wall and window between dining and study room
3 Slidng door, grill and metal realing at balcony
4 Sink support and existing kitchen cabinet
5 Door and door frame, wc and basin at two toilet
6 Whole house window grill
a Door and door frame at study room
7 Floor tiles and wall tiles for whole house
8 All existing cornice
9 Houlage fees
10 Parking for skip tank fees
11 New opening between access balcony and kitchen
B) Wet works(Tiles at $4.00)P.S.F -homogeneous tile heavy duty - $15,500.00
To supply labour and materials to:
1 Lay floor tiles c/w skirting ****, dining and study room and balcony $3,730.00
2 Lever up balcony $200.00
3 Lay floor tiles c/w skirting at main bedroom, bedroom 2 and bedroom 3 $3,320.00
4 Lay wall tiles at kitchen (Expose area only) $1,860.00
5 Lay floor tile at kitchen $1,100.00
6 To construct cabinet, fridge and washing machine base $350.00
7 Lay wall tiles w/o border tiles at two toilets $2,460.00
8 Lay floor tiles c/w water proofing at two toilets $1,100.00
9 To construct shower kerb at two toilets $180.00
10 Lay floor tiles at access balcony $600.00
11 To construct hollow block wall to seal up existing entrance at study room $300.00
12 To construct hollow block wall for main entrance $300.00
C) Plastering Works - $3,800.00
1 Wall and ceiling plastering for whole house includes access balcony
D) Plumbing Works - $1,050.00
1 To run copper piping (one way) at kitchen and two toilet $530.00
2 To run inlet and outlet pipe for washing machine $100.00
3 Labour to install two nos toilet bowl and two nos basin $200.00
4 Labour to install 02 sets instant heater for two toilet $120.00
5 Labour to install toilet accessories $100.00
E) Electrical Works - $2,700.00
1 New DB 01 no x S$ 320.00 $320.00
2 20A air con point 01 no x S$ 120.00 $120.00
3 13A x 2 Power point 15 nos x S$ 55.00 $825.00
4 13A x 1 power point 06 nos x S$ 55.00 $300.00
5 SCV point 02 nos x S$ 90.00 $180.00
6 Tel point 01 no x S$ 40.00 $40.00
7 Heater point 02 nos x S$ 80.00 $160.00
8 Hood point 01 no x S$ 80.00 $80.00
9 Lighting point 15 nos x S$ 35.00 $525.00
10 Install light 15 nos x S$ 10.00 $150.00
F Painting Works - $1,870.00
Supply labour and materials to :
1 1 coat of sealer for all wall and ceiling $400.00
2 I.C.I or Nippon paint for whole house $1,350.00
3 4 set of metal door frame $120.00
G Cornice Works - $1,250.00
1 Simple cornice ****, dining,balcony and 03 bedroom $950.00
2 Box up piping at balcony $150.00
3 Box up piping at access balcony $150.00
H) Window and Door - $5,750.00
1 01 set of wrought iron main gate $500.00
2 01 set of solid nyatoh main door with door frame c/w lockset in vanish finish $830.00
3 To re-varnish 04 sets of door $220.00
4 02 set of aluminium frame with aluminium panel sliding door at two toilet $480.00
5 01 set N.A aluminium sliding window c/w tea glass at balcony $820.00
6 01 set N.A aluminium sliding window c/w tea glass at access balcony $980.00
7 N.A alu. Sliding grill for whole house(8 sets) Approx. 250 sqft $1,500.00
8 Adjustable louver at 02 toilet $420.00
I) Carpentry Work - $20,680.00
Supply labour and materials to install :
1 Design and built top and bottom kitchen cabinet (45 ft) $4,500.00
2 Supply and install solid surface work top (17 ft) $1,360.00
3 Design and built temp. glass sliding door with pelmet at study room entrance(6.5ft) $1,360.00
4 Design and built TV console c/w deco panel **** (7 ft) $1,300.00
5 Woodply raise up platform at main bedroom (100 sqft) $800.00
6 Design and built storage cabinet at main bedroom (5 ft) $850.00
7 Casement door wardrobe in laminate finished at main bedroom (7.5 ft) $1,500.00
8 Woodply raise up platform with drawer set at bedroom 2 (70 sqft) $680.00
9 Low study table with top hung cabinet at bedroom 2 (6 ft) $800.00
10 Sliding door wardrobe with laminate and aluminium frame at bedroom 2 (8 ft) $1,720.00
11 Mirror with wood frame at bedroom-2(2.5 ft) $380.00
12 Full height book with pigeon hole display at study room (11 ft) $1,960.00
13 Low cabinet at study room(10 ft) $800.00
14 Work table (8.5 ft) $450.00
15 Cantilevered shoes cabinet at access balcony(7 ft) $600.00
16 Design and built low cabinet under window area at dining(8.5 ft) $760.00
17 To supply and install vanity cabinet with mirror and alu. Door at common toilet(5 ft) $860.00
J) Others - F.O.C
1 H.D.B submission $200.00
2 Acid wash $350.00
3 Spray paint glass at kitchen cabinet area $820.00
4 Display shelving at access balcony $280.00
Seems a tad exp to me. Not just a few items, but just about everything seems to be at least 10-20% more exp than the quotes I've seen from other contractors. Very simple example, 5rm flat painting I've seen about $1000, but yours is $1350. Wrought iron gate about $400, yours $500. Lights installation $8 per point, yours is $10.
Hi All!
9 Houlage fees
J) Others - F.O.C
2 Acid wash $350.00
Seem a little high side except for electrical work, i have pm you my contractor's contact and perhaps u can get a quote from him to compare. im sure u can get a better deal.
Cheers.
