feizhu
Renovation Quote (comments Please)
Hi folks,
Just received a quote from my contractor for a 4 room private apt. Can please help me take a look and let me know if its reasonable? Thanks in advance! :)
Demolition works
Dismantle existing laminate flooring in 3 bedrooms $750
Hack off existing floor and wall tiles in kitchen & yard $700
Hack off existing floor and wall tiles in 2 toilets $1200
Hack off portion of wall between kitchen & yard $280
Haulage $680
General
Painting of whole house (over 8.5ft height) - Up to 6 colours (Nippon 3 in 1/ ICI Dulux) $1700
Chemical washing for whole house (2 times) $350
Waterproofing membrane in kitchen, yard and 2 toilets $380
Conceal copper piping works:
- Kitchen (hot & cold) $700
- 2 toilets (hot & cold) $1600
- Washing machine (cold) $350
Provide protection cardboard for all doors and marble flooring $300
Dismantle and fixing 2 toilet doors $200
Repolish marble flooring in living and passageway $800
Kitchen/Yard
Supply and lay 60x60cm homogeneous floor tiles up to 170 sqft in kitchen and yard area. Tiles range up to $3.20psf. Includes raw materials. $1190
Supply and lay 60x30cm homogeneous wall tiles up to 320 sqft in kitchen area. Tiles range up to $3.20psf. Includes raw materials. $2240
Design & fabricate kitchen cabinet up to 38ft (top & bottom) $4180
- 6100mm (L) x 300mm(D) x 700mm (H) - Top
- 5200mm (L) x 600mm (D) x 800mm (H) - Bottom
- Solid plywood using laminate finishes (includes abs trimmings)
- Internal in polyster white
- Includes dish drainer
- Excludes sink & cooker hob & top
Supply & install solid surface up to 17ft in kitchen $1120
- 5200mm (L) x 600mm (D) x 12mm (H)
MBR Toilet
Supply & lay 30x30cm homogeneous floor tiles $700
- Tiles range up to $2.80psf
- includes raw materials
Supply & lay 30x60cm homogeneous wall tiles up to 290sqm $1740
Supply labour to install 1 basin $80
Supply labour to install 1 toilet bowl $100
Taps and toilet accessories install FOC
Supply & install casement door 10mm tempered glass shower screen $560
- 1600mm (L) x 10mm (D) x 1800mm (H)
Design & fabricate basin cabinet up to 6ft
- Bottom cabinet 1900mm (L) x 600mm (D) x 700mm (H) $660
- Solid surface 1900mm (L) x 600mm (D) x 20mm (H) $480
- Mirror 1900mm (L) x 5mm (D) x 1800mm (H) $350
- Solid plywood using laminate finishes (includes abs trimming)
- Internal in polyester white
Common Toilet
Supply & lay 30x60cm homogeneous wall tiles up to 270sqm $1620
- Bottom cabinet 1000mm (L) x 600mm (D) x 700mm (H) $330
- Solid surface 1000mm (L) x 600mm (D) x 20mm (H) $240
- Mirror 1000mm (L) x 5mm (D) x 1800mm (H) $230
Master Bedroom/Bedroom 2/Bedroom 3
Supply & overlay laminated flooring up to 200sqft in MBR $900
- Laminate range up to $3.60
Supply & overlay laminated flooring up to 140sqft in bedroom 2 $630
Supply & overlay laminated flooring up to 140sqft in bedroom 3 $630
Ceiling works
Dismantle existing ceiling works in kitchen & 2 toilets $200
Construct ceilings works as follows:
- Living/dining/passageway $1500
- Kitchen $600
- 2 toilets $600
- MBR $950
- Bedroom 2 $800
- Bedroom 3 $800
Air Conditioner (Conceal)
Supply & install Mitsubishi inverter system 1 for living/dining area (24000 BTU) $3000
Supply & install Mitsubishi inverter system 3 for 3 bedrooms (1 x 12000 BTU, 2 x 9000 BTU) $3600
Supply & install 2 brackets $300
Carpentry
Design and fabricate suspended tv console & feature wall backing up to 10 ft in living area $2600
- 3000mm (L) x 550mm (D) x 2800mm (H)
Construct timber platform with storage up to 70 sqft in bedroom 2 $840
- 2900mm (L) x 2500mm (D) x 200mm (H)
Design and fabricate breakfast counter in entrance area $1820
- 2000mm (L) x 300mm (D) x 2800mm (H)
Total price is $47190 before any goodwill discount. :paint:
Edited by feizhu
