reglxt
Our Cosy Little House
ok today i tried the ariston water heater tank (TI shape series) for the first time
it took **** long, 26 mins to heat up the water so its not recommended
should had done my research before buying..didnt expect heating time to be this loooong.... sigh
this was not brought up to me when i purchase the heater also i didnt ask .. should had done my research before buying..didnt expect heating time to be this loooong.... sigh
http://www.ariston-heater.com.sg/pdf/Plus%20Series.pdf
:jawdrop: :jawdrop:
1/2 hr to heat up? *faint*
Swee! Soon u will have people knocking on Yr door asking where u bought it. :D
Perharps I should DIY one pc for myself.. :P
the cost of diying 1 pc is rather high as the thick acrylic sheet is pretty costly then the spacer sold here so far i came across are huge and heavy.. the ones they gave is aluminium and light weight
i didnt drill any hole just uses 3m heavy duty tape.. sticks on pretty well
Hmmm... I'll try to source around, if not worth it then I'll buy fr eBay. Hw much u got it including shipping?
Hi reglxt...
been following your t-blog... finally register myself to ask u some question... :P
can you pm me the cost of
- invisible grill
- door sign (all in all how much u paid)
- ur reno cost
it's very nice!!!! hope to hear frm u~
Hi reglxt...
- invisible grill
- ur reno cost
thanks kyxyy
pm sent :)
the number sign + freight around $30 one set
Wah! Very chio and affordable! (though i don't know how much the normal SOP kind cost). BUT yours really looks :good:
But sometimes, i very scared to do such nice stuff, coz don't know if got noisy neighbours or naughty kids, later poke poke here touch touch there... then damaged le... I'll be very :(
LOL... just a thought... this door sign, can organize Group-Buy or not? hehehe
Edited by csingeu
thanks thanks.. but if you put it high up then shouldnt be a problem :)
btw, your spycam - is it wireless ip cam? how much did you get it for?
I'm thinking of installing a wireless ip cam at my main door pointing towards the access corridor.
So that next time, if got people knock on door or press door bell, if I'm upstairs, i don't need to come down to peek thru peekhole, can just use ipad, iphone, or laptop to view to see if it's friends/relatives or salesman...
:P
Edited by csingeu
thx! btw can pm me hw much were u quote for the kdk toilet exhaust fan installation?
i remember reading a thread on the installation charges, but cant find it..
if i can manage to find a cheaper one, i'll let u know..
:P
you will still be installing the camera within your premises right? if along common corridor.. not too sure if you need permit thou..
i saw a CCTV thread under "home living" section maybe u wanna check it out?
i got this Wireless IP indoor IR Camera from ebay ( ya ebay again ) total cost + freight around $80 bucks.. just need to ask contractor help you build one power point can liao .. plug and play..
some info about the cctv
Easy Installation
IP cameras are easy to install and operate, and have the ability to work totally wirelessly through your network. The camera displays in full color, and has infrared capabilities for nighttime shooting.
Remote Viewing
FOSCAM IP cameras allow for remote viewing from any internet-connected device, including iphones and other smart phones. Log in from anywhere in the world to view a live streaming video feed, and control the camera remotely.
Image Capabilities
Our cameras are geared towards providing the best security, so high quality is a must. At 30 frames per second with a resolution of 640×480, you’ll get a clear and detailed image of your monitored area, day and night. FOSCAM cameras use MPEG compression, which allows for high quality images with less space requirements on your hard drive.
Additional Features
The included software is capable of supporting of multiple simultaneous users, which allows for complete security of your workplace. The data is also encrypted through WPA or WEP security, to ensure peace of mind and complete privacy.
FOSCAM IP cameras come with all of the features you need and expect in a security camera. With its the high quality image and sound, remote viewing capabilities, wireless convenience and encrypted security, this camera provides the perfect security solution for your home and office needs.
Note: Our cameras come equipped with a US power adaptor. Buyers from countries outside of the US may need to use an adaptor for their respective countries.
The improved Features of FI8918W compared to FI8908W:
1) Nicer looking appearance
2) Add IR-LEDs software switch, the IR-LEDs could be shut off or on by software switch.
3) Move the signal green LEDs to the back of the camera
4) Add power indication LED on the back of the camera
5) More wide pan degree up to 300 degree on horizon.
6) Add Mic Jack & Speaker Jack on the back of the camera
7) Move the built-in mic to the bottom of the camera, separated from the speaker on the head, which has better audio than FI8908W.
product name: FI8918WB
Features:
>Simple to setup, Friendly GUI, DIY installation
>High image & video quality,Two-way audio monitoring
>Allow remote Pan/Tilt control (Pan:300°& Tilt:120°)
>Freely control IR-LED on/ off
>Auto IR-LED illumination for night vision (up to 8 metres)
>Allow remote viewing & record from anywhere anytime
>Support IE browser or any other standard browsers
>Wi-Fi compliant with wireless standards IEEE 802.11b/g
>Support both WEP & WPA WPA2 Encryption
>Motion detection alert via email or upload image to FTP
>Multi-level users management with password protection
ITEMS FI8918WB
Image Sensor Image Sensor 1/4" Color CMOS Sensor
Disaplay Resolution 640 x 480 Pixels(300k Pixels)
Lens f: 3.6mm, F:2.4 (IR Lens)
Mini. Illumination 0.5Lux
Lens Lens Type Glass Lens
Viewing Angle 67 Degree
Audio Input Built-in Microphone
Output Built-in Speaker
Audio Compression ADPCM
Video Image Compression MJPEG
Image Frame Rate 15fps(VGA),30fps(QVGA)
Resolution 640 x 480(VGA), 320 x 240(QVGA)
Flip Mirror Images Vertical / Horizontal
Light Frequency 50Hz, 60Hz or Outdoor
Video Parameters Brightness, Contrast
Communication Ethernet One 10/100Mbps RJ-45
Supported Protocol HTTP,FTP,TCP/IP,UDP,SMTP,DHCP,PPPoE,DDNS,UPnP,GPRS
Wireless Standard IEEE 802.11b/g
Data Rate 802.11b: 11Mbps(Max.), 802.11g: 54Mbps(Max.)
Wireless Security WEP & WPA WPA2 Encryption
Physical Pan/Tilt Angle Horizontal:300° & Vertical: 120°
Infrared Light 11 IR LEDs,Night visibility up to 8 metres
Dimension 110(L) x100(W) x108mm(H)
Gross Weight 768g (Color Box Size:200x124x189mm)
Net Weight 418g ( accessories included)
Power Power Supply DC 5V/2.0A (EU,US,AU adapter or other types optional)
Power Consumption 5 Watts (Max.)
Environment Operate Temper. 0° ~ 55°C (14°F ~ 122°F)
Operating Humidity 20% ~ 85% non-condensing
Storage Temper. -10°C ~ 60° (14°F ~ 140°F)
Storage Humidity 0% ~ 90% non-condensing
PC Requirements CPU 2.0GHZ or above (suggested 3.0GHz)
Memory Size 256MB or above (suggested 1.0GHz)
Display Card 64M or above
Supported OS Microsoft Windows 2000/XP/Vista
Browser IE 6.0, IE7.0,Firefox or other standard browsers
Certification CE,FCC
Edited by reglxt
hmm.. not too sure if you can get such price outside
cos my contractor did the whole reno for me + change of toilet windows + installation of fan so will be cheaper than normal, imo
will pm you the price
heres the pic
