Drexter
Laminated Flooring
Anyone using this? Look very promising and durable and Water proof....
Hi (:
Not sure if it works but i know all laminate floor have a certain level of water resistance. The only issue should be at those corner where the plank is saw off. Laminate plank itself is coat with wax at all the 4 corners but once you reach the corner,you need to saw it off. Thats where it is expose. Hence if water slip in from the side,then only the flooring will be affected.
I believe in the middle of the laminate if you spill a cup of water,there should be any issue.
