existence
Le Grand Switches
Hi all renotalkers!!
I got the Le Grand Water Heater switch and find that it is hard to press to turn on/off it.
I went back to Choo Chiang and the salesperson say it's common.
Are you guys having the issue? Can anything be done?
Thanks in advance. :)
Normal. Need to have fast on contact & fast off contact for high ampere to reduce the electric arc/spark. After on/off for some time, you will use to it.
Edited by bepgof
You sure it's ok?
I tried the Clipsal and MK water heater switch and it works smooth.
Not sure why the Le Grand one is so hard to press. :unsure:
As sure as the sun will rise from the east tmr. I'm using Legrand brand too. The spring is strong.
You sure it's ok?
Edited by bepgof
