sng28
Id & Contractor Quote Do Not Diff For My 2+1 Condo Unit......
Hi guru bros and sisters...i've seen about 6-7 Ids and contractors and apparently the bill are always very similar to each other...there isnt any price diff at all...can i ask if its my ID charging cheaply or the contractors are carroting me...I've appending a quote from one of the ID recommended by RT forummers here...as reference..
RE: QUOTATION FOR THE ABOVE INTERIOR DESIGN & RENOVATION WORKS
1.0 - PROFESSIONAL SERVICES
1.1 Design consultation FOC
1.2 Space Planning FOC
1.3 Perspective Drawings FOC
1.4 Material & Colour Proposal FOC
1.5 Project Management : FOC
2.0 - DEMOLITION WORKS
2.1 To supply labour & hack existing floor tile for kitchen $ 230.00
2.2 To supply labour & hack existing floor tile for yard $ 180.00
2.3 To supply labour & hack existing floor tile for common toilet $ 180.00
2.4 To supply labour & demolish existing toilet accessories & sanitary ware at
both toilet $ 120.00
2.5 To supply labour & remove existing vanity at master toilet $ 80.00
2.6 To supply labour & remove existing kitchen cabinet with disposal by M.O.E
regulation $ 220.00
2.7 To supply labour & remove wardrobe at master room with disposal by
M.O.E regulation $ 150.00
2.8 To supply labour & wooden partition at foyer with disposal by M.O.E
regulation : $ 120.00
SUB-TOTAL $ 1,280.00
3.0 - MISCELLANEOUS WORKS
3.1 To supply & paint of wall & ceiling for whole house include all expose
piping ( matex paint ) $ 1,400.00
3.2 To supply & vanish existing 4 set door & door frame $ 320.00
3.3 To supply & vanish existing 2 set sliding door & door frame $ 300.00
3.4 To supply & vanish existing 1 set bi-fold door & door frame $ 120.00
3.5 To supply & vanish existing 3 pcs wood plank at window bay $ 240.00
3.6 To apply for skip tank permit $ 150.00
3.7 To haulage material to unit c/w debris disposal $ 350.00
3.8 To supply labour for general cleaning whole house include acid cleaning
for floor, wall & window $ 250.00
3.9 To supply & plaster kitchen wall with Alturas hard $ 750.00
SUB-TOTAL : $ 3,880.00
4.0 - PARQUET WORKS
4.1 To suppply & revanish existing parquet flooring for 3 bed room $ 430.00
SUB-TOTAL : $ 430.00
5.0 - PLUMBING WORKS
5.1 To supply labour to joint in/out let pipe for kitchen sink $ 150.00
5.2 To supply labour & install 01 no wash basin at master toilet c/w lever tap $ 60.00
5.3 To supply labour & install 01 no wash basin at common toilet c/w lever tap $ 60.00
5.4 To supply labour & install 01 no sitting bowl c/w flashing tank at master
toilet $ 120.00
5.5 To supply labour & install 01 no sitting bowl c/w flashing tank at common
toilet $ 120.00
5.6 To provide labour to install toilet accessories at master toilet $ 40.00
5.7 To provide labour to install toilet accessories at common toilet $ 40.00
SUB-TOTAL : $ 590.00
6.0 - MASONRY WORKS
6.1 To supply & lay matt finish homogenous tile for kitchen ( tile up to $2.80
psf ) $ 900.00
6.2 To supply & lay matt finish homogenous tile for yard ( tile up to $2.80 psf ) $ 550.00
6.3 To supply & lay matt finish homogenous tile for common toilet ( tile up to
6.4 To supply & apply water proofing membrane for kitchen & commn toilet
flooring $ 180.00
6.5 To supply & construct 50mm cabinet base with tile skirting $ 280.00
6.6 To supply & construct shower curb at common toilet with tile finish $ 80.00
6.7 To supply & construct sink support with hollow block & 60x60 polish
homogenous tile finish $ 850.00
SUB-TOTAL : $ 3,390.00
7.0 - CARPENTRY WORKS ****
7.1 To supply & fabricate 6 ft designed TV consol with laminate finish $ 660.00
SUB-TOTAL : $ 660.00
8.0 - CARPENTRY WORKS AT MASTER BEDROOM
8.1 To supply & alter existing wardrobe c/w new cabinet & laminate finish $ 750.00
8.2 To supply & fabricate king size bed c/w pull out drawer & laminate finish $ 1,000.00
8.3 To supply & fabricate 2 set wall mounded 2.5 ft shelf c/w laminate finish $ 200.00
8.4 To supply & fabricate 2.5 ft designed full high wardrobe c/w glass swing
door aluminium frame & laminate finish $ 625.00
8.5 To supply & fabricate 4.5 ft designed suspened study table c/w laminate
finish $ 540.00
SUB-TOTAL : $ 3,115.00
9.0 - CARPENTRY WORKS AT STUDY ROOM
9.1 To supply & fabricate 9.5 ft designed full high walk in wardrobe with colour
polyester board $ 2,090.00
9.2 To supply & fabricate 3 ft suspended drassing table with laminate finish $ 300.00
9.3 To supply & install 1 pc 3 x 6 ft mirror for drassing table $ 180.00
SUB-TOTAL : $ 2,570.00
10.0 - CARPENTRY WORKS AT KITCHEN
10.1 To supply & fabricate 32 ft solid plywood kitchen cabinet c/w laminate
finish, 2 glass door, 4 drawer, 1 cutlery tray & 1 stainless steel dish tray $ 3,200.00
10.2 To supply & install 18 ft solid INDIA granite work top with 3 inch profile $ 1,800.00
10.3 To supply & install L-shape glass backing at cabinet area $ 750.00
10.4 To supply & fabricate 3 pcs cabinet door at support c/w laminate $ 285.00
SUB-TOTAL : $ 6,035.00
11.0 - CARPENTRY WORKS AT MASTER TOILET
11.1 To supply & fabricate 3 ft suspended vanity cabinet c/w glass door
aluminium frame & laminate finish $ 390.00
11.2 To supply & install 3 ft INDIA granite work top c/w 2 inch profile $ 300.00
SUB-TOTAL : $ 690.00
12.0 - CARPENTRY WORKS AT COMMON TOILET
12.1 To supply & fabricate 3 ft top hung store cabinet with laminate finish $ 330.00
SUB-TOTAL : $ 330.00
13.0 - GLASS WORKS
13.1 To supply & change 6 mm tick glass at yard door with clear finish $ 250.00
13.2 To supply & change 6 mm tick glass at yard window with clear finish $ 160.00
13.3 To supply & install 10mm tick tampered glass shower screen at common
toilet c/w swing door $ 750.00
SUB-TOTAL : $ 1,160.00
14.0 - MARBLE WORKS
14.1 To supply & repolish existing marble flooring **** & dinning $ 691.20
14.2 To supply & repolish existing marble flooring at master toilet $ 180.00
14.3 To supply & wax existing marble wall tile at master toilet $ 80.00
SUB-TOTAL : $ 951.20
15.0 - WIRING WORKS
15.1 To supply labour to install 2 light at foyer $ 24.00
15.2 To supply labour to install 1 light at study $ 12.00
15.3 To supply labour to install ceiling fan at room 2 $ 45.00
15.4 To supply labour to install 1 light at master room $ 12.00
15.5 To supply labour to install ceiling fan at master room $ 45.00
15.6 To supply & relocate 1 double point at study ( conceal ) $ 100.00
15.7 To supply labour to run double point at master room $ 75.00
15.8 To supply labour to run SCV point at master room : $ 95.00
SUB-TOTAL $ 408.00
GRAND TOTAL :
$ 25,489.20
THe final price he is willing to close the deal at is $25k......
Dear guru bros and sis if you see this repost pls pardon me as thats becoz im unable to see the post which i've previously submmitted hence...am redoing this again.......can you advice me if this quotation from ID is okie as i've been to 5-7 ID and contractors and their quotations are the SAME....i wonder why...its either the ID are cheap or the contractors are chopping me....pls pls advice..
1.0 PROFESSIONAL SERVICES
2.0 DEMOLITION WORKS
regulation $ 220.00
3.0 MISCELLANEOUS WORKS
4.0 PARQUET WORKS
SUB-TOTAL : $ 430.005.0
PLUMBING WORKS
toilet $ 120.00
toilet $ 120.00
6.0 MASONRY WORKS
psf ) $ 900.00
flooring $ 180.00
SUB-TOTAL : $ 3,390.007.0
SUB-TOTAL : $ 660.008.0
finish $ 540.00
SUB-TOTAL : $ 3,115.009.0
SUB-TOTAL : $ 2,570.0010.0
11.0 CARPENTRY WORKS AT MASTER TOILET
SUB-TOTAL : $ 690.0012.0 CARPENTRY WORKS AT COMMON TOILET
SUB-TOTAL : $ 330.0013.0
GLASS WORKS
SUB-TOTAL : $ 1,160.0014.0
MARBLE WORKS
SUB-TOTAL : $ 951.2015.0
WIRING WORKS
SUB-TOTAL $ 408.00
GRAND TOTAL :
$ 25,489.20
Final Price is $25k Nett after 'discount'......
Edited by sng28
