dragon888
Advice On Quotation
I received the following quotation for some renovation works for my existing flat and would like to check with all the experienced folks here if the quote is reasonable. Thank you.
A) Masonry
1 Remove existing aluminum frame and sliding door and made good damaged wall and ceiling. 180.00
2 Labor charges to hack existing balcony flooring and overhead beam and made good damaged wall and ceiling. 380.00
3 Labor charges to remove existing living hall wooden architraves trimming, both bathrooms shower screen and common bathroom bi-fold door. 150.00
4 Supply labor and material for chemical washing, cleaning and handing over of project. 250.00
5 Supply labor and transport to clear all existing renovation debris. 250.00
B) Wet Works / Aluminum Doors / Shower Screen
1 Supply and raise balcony flooring to level with living hall flooring complete with approved extruded polystyrene foam and fine wire mesh re-enforcement. 300.00
2 Supply and lay new floor tiles at extended living hall floor similar to existing living hall flooring complete with similar tiles as 75 mm ht. skirting. 550.00
3 Supply and install white powder coated aluminum frame complete with acrylic panel Bi-fold doors at both bathrooms entrance. 560.00
4 Supply and install 02 sets of white powder coated aluminum frame c/w tempered glass doors at common bathroom and L/shape shower screen at shower area. Size: (L1.7 x Ht1.7) + (L838 + 1300) x Ht1.8m 1,300.00
All tiles quoted above are based on $2.50 p.s.f. unless stated.
C) Carpentry / L-box / Painting
1 Supply and install 02 unit storage cum display cabinet at bedroom 2 and bedroom 3 existing recess areas. Size : (L685 X Ht2400 x D300) mm 1,150.00
2 01 no. feature wall at dining hall complete with wooden backing and 5 mm thick clear mirror. Size: (L3720 x Ht1500)mm 1,450.00
3 Supply and install fiber glass plaster board L/box at extended living hall ceiling. 380.00
4 Supply and install fiber glass plaster cornices at extended living hall ceiling. 220.00
5 Supply and paint whole house interior walls and ceiling complete with ICI / Nippon paint 1,100.00
6 Supply and paint 04 nos. of doors and 05 nos. of doorframes and exposed sanitary pipes at kitchen and both bathrooms. 350.00
7 Supply labor and material to varnish 01 main door. 80.00
