dcool
Suggestions With Aircon Installation
Hi Everyone,
I need to seek opinion on the installation of the aircon system for my unit which i just bought. The problem is that the Bdrm 3 is across the living from Bdrm 2 and the MBR. So I have problem figuring the best A/C system to install for my unit.
I need to install A/C in Bdrm 3, Living room and the MBR. Bdrm 2 is going to be my wardrobe and study so it doesnt really need a/c.
Now my headache is that if i get system 3, will the installer be able to run the tubings across the living room or its it better to get a system 2 for the MBR and the living and then a System 1 or a window unit for Bdrm 3 ? I am not sure if its advisable to go for system 3 as the drain line from the Bdrm 3 will be too far away and sooner or later its going to get choked. Someone suggested using a pump to pull condensate water to the drain, which i thgt installing another item is pretty ugly and most likely it will may run dry as the condensate is not really alot. Another option is the install a stand alone window unit for Bdrm 3.
I have not started my reno yet, and i hope to get the A/C fixed before i start the reno in Jun.
I really hope to hear from flat owners who have similar layout and their suggestion on how to do it.
Sorry it seems that i am not allow to embed image so here is the floor plan in the link below.
Floor Plan
In my opinion, if cost is not an issue to you and insisting to have an aircon in the living room. I would suggest :
For Bedroom 3: Window Unit. Your toilet is further away from toilet so water piping outlet for aircon would need to lay far.
System 2: For MBR & Living Room. Since your living room needs a bigger BTU aircon, must as well get 2 bigger BTU for both your MBR and living room.
Up to you to decide.
