NO. DESCRIPTION AMOUNT
Hacking & Dismantle Works
1a To hack existing floor tiles at 02nos toilet & kitchen area.
1b To hack existing wall tiles at kitchen & 02 nos toilet .
1c To dismantle existing kitchen cabinet.
1d To dismantle existing 02 nos toilet's shower screen, w.c & basin.
1e Haulage sevice & debris remover after renovation. $ 2 ,300.00
Tiling Works
2 To supply & lay 110sqft of homogeneous floor tiles at 03 nos toilet with water $ 1 ,550.00
proofing.
3 To supply & lay 166sqft of homogeneous floor tiles at kitchen, yard & utility room. $ 1 ,240.00
4 To supply & lay 660sqft ceramic wall tiles at 02 nos toilet & kitchen area. $ 4 ,950.00
Plumbing Works
5 To supply & conceal cold & hot water piping for 02 nos toilet ,kitchen & washing $ 2 ,200.00
machine area.
6 To supply labour to install 02 nos wash basin & kitchen basin. $ 2 40.00
7 To supply labour to install 03 nos W.C. $ 2 40.00
8 To supply labour to install toilet accessory. $ 2 40.00
9 To supply labour to install 02 nos storage heater $ 1 60.00
Carpentry Works
10 To fabricate & install L4350mm top & bottom kitchen cabinet in laminate finish. $ 3 ,200.00
11 To supply & ouver lay new laminate on existing wardrobe at master bedroom. $ 9 50.00
12 To fabricate & install L1000mm wardrobe at master bedroom (internal laminate finish) $ 1 ,040.00
13 To fabricate & install L2000mm storage cabinet with mirror door at dinning area. $ 2 ,400.00
14 To fabricate & install L1900mm vanity cabinet at master toilet. $ 9 10.00
15 To fabricate & install L800mm vanity cabinet at common toilet. $ 4 20.00
16 To fabricate & install 05 nos plywood laminate column **** room. $ 1 ,250.00
17 To fabricate & install L1950mm top cabinet & study table at bedroom 2. $ 1 ,740.00
18 To supply & install L3710mm white colour solid surface for kitchen cabinet top. $ 8 70.00
19 To supply & install L2700mm white colour solid surface top for 02 nos toilet. $ 6 30.00
20 To fabricate & install L1800mm suspendes TV console at master bedroom. $ 7 80.00
Glass Works
21 To supply & install 01 no swing glass door at master bedroom. $ 8 20.00
22 To supply & install 02 nos shower screen for common & master toilet. $ 1 ,450.00
23 To supply & install normal mirrow with wooden backing at master bathroom. $ 7 50.00
24 To supply & install L600mm tempered colour glass for kitchen backing $ 3 50.00
Cornice Works
25 To supply material & install 190sqft false ceiling **** room. $ 9 50.00
26 To supply material & install light holder **** room & Dinning area. $ 6 30.00
27 To supply material & install 90sqft false ceiling at master bedroom. $ 4 50.00
28 To supply material & install light holder at master bedroom. $ 3 00.00
Miscellaneous Works
28 To supply & paint whole unit( wall & ceiling )with ICI / NIPPON emulsion paint. $ 1 ,400.00
29 Chemical washing for whole house. $ 2 80.00
F.O.C Works
1 Pebblewash **** room area.
2 Supply & install 06 no aluminium glass door for study room's wardrobe.
Total : $ 3 4,690.00
Discount : $ 1 ,690.00
Grand Total : $ 3 3,000.00
this is the cheapest quote I have gotten from a contractor my friend has recommended. Very hardworking and responsive. And the best is, he is not very greedy as compared to other quotes I've received. Btw, he did not charge me those small items like skirting tiling, base for fridge and washer etc. I'm most likely to go with him if there is no comment on his quotes.
jus wondering y never quote on the electrical .
Electrical works for whoe house can cost ard $2k to 3k
haulage services abit ex ,
Please take note
Edited by billi
frankly speaking, the price quoted is consider cheap compare to quotes which I got for my reno.
Moreover, they are giving you an overall discount.
Good quotes.
your quote is expensive. I went through your items in detail. it's exp.
TS, why not you take each item and calculate the per unit price - $/ft, $/sqf etc. (where applicable)
Then i'll show you for each item where the market rate should be.
I initially thought your quote was cheap BUT realised the quote is mainly for toilet n kitchen mainly.
chop chop cully pok... do find more quotes
