Wen Wen
Did You Check If Your Aircon Compressor Is Screw On Or Just Placed Onto A Aircon Bracket
Did you check if your aircon compressor is SCREW on or just PLACED onto a aircon bracket?
As today my ID told me they dont screw the aricon compressor onto the aircon bracket as future it cannot be remove. But i am worried it may drop downstairs and hurt
someone...
So it is true that the aircon compressor is not secure onto the bracket via screws?
Thanks
Wen
someone...
Thanks
Wen
Yes they are screwed. I got mine installed few months ago
Thanks Jimtan but may i ask which floor is your house and your aircon is not install on those newer HDB which have an aircon ledge right? Itis mounted on an aircon bracket supported by 4 screws from your bedroom?
Thanks
Wen
For HDB flats with an air con ledge, normally I dun see installers bolting the compressor to the floor. Dun think there is any safety issue on this as all HDB air con ledges are surrounded by railings.
As for older flats with no air con ledge, the compressor is mounted on the aircon rack supplied by the air con installer, and yes the compressor is bolt on the bracket
Thanks
Wen
I live in 10 floor old Hdb flat where air con compressor is mounted on the bracket secured with bolt. Yes the bracket is supported by 4 screws from my bedroom.
