velv
Can Blue Tac And Copper Wire Use To Hand Lanterns On Ceiling
hello
like to find out how can I hang little deco on ceilings for festivals.
is blue tac and copper wire good? can it stand the wind??
Maybe you want to try 3M hooks?
Easier to remove and will not leave 'stain' like blue tag. They have either white color or transparent so look better.
Try search their site to understand which one suits you. You can get them easily from fairprice supermarket.
3M General Hooks
use scotch tape can le...
hello
hello
scotch tape isnty strong enough. if it is, it will peel off the paint.
blue tac.. cannot .. not strong enough.
3M will be better but high cost if you going to hung quite a number of lanterns. Then you need to remove one by one. Very waste.
May be you can think of cable tie. Cut and thrown after use.
Wat kind of lantern? Those with burning candles one?
Just be be safe, use something strong like the double sided tape that has the sponge material.
If you wanted to take down and scared that it will leave stains or peel the paint, you can use some methylated spirits to remove it.
The spirits can easily be bought from your neighbourhood hardware shop.
