uris
Led Ceiling Light Wihout False Ceiling
HI All,
Will like to check if it is possible to achieve LED lightning without any false ceiling (e.g. maybe a light fixture with light bulbs or any LED circular fluorescent replacement?)?
Also very blur as to calculate how many lumens a room need and etc. My current house, just use 40w circular fluorescent light and my rooms, 32w.
Any help or guide will be appreciated! Thanks!
Sorry what you mean LED bulbs in light fixtures?
I see all those LED bulbs lumens like very little leh hmmm.
Wonder got any show room for me to see anot. But not those with false ceiling requirement 1 cos I not planning to have false ceiling leh
Uris,
If you choose to install surface mount LED lamp in your room without false ceiling, very likely it is going to be a big size ceiling light with LED globe shape bulb installed inside. Ring shape hamburger LED lamps are still not bright enough due to heat dissipation issue.
You can consider E27 LED bulb or LED fluorescent tube for your room. These products are able to provide equivalent brightness as conventional lighting.
