zero
LG Condensor Dryer 8KG
Brand : LG
Model : TDC8012
Price : $955 * With free delivery
Key Features
Temperature Sensor
Moisture Sensor
Sensor Dry Clean
Filter Indicator
Empty Water Indicator
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Thank you for the Support!
All Sold!
Special buy for first 5sets only.
Cheapest Sharp New LED 50Inch TV 50LE450 @ $???
Brand : Sharp
Model :50LE450
Price : $??? *Inclusive of free delivery, wall mount and 3years local warranty from sharp
  • TV Type: LED 50 inches
  • Resolution: Full HD 1920 x 1080
  • Scanning Frequency: 50 Hz
  • Connectivity: HDMI x 3, PC in x 1, USB x 1, Headphone x 1
  • Technology: USB 2.0 see the movies, listening to music, watching movies
Thank you.
Regards,
Jerome
92256638
Rinnai HOB & HOOD
Inner Flame from Rinnai
Rinnai Inner Flame
Innovation flame technology Japan with patented aluminium air inlet frame provides steadier heat combustion producing the highest heat efficiency while its concentrated point of flame distributes even heat. The perfect flame control for Asian Cooking.
The appliance-maker Rinnai has turned burner design completely around with its inner-flame burner. The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan. Hence, it requires less gas consumption yet heat up the food faster as compared to the normal ordinary burner.
Rinnai's exclusive "Inner Flame"
Powerful & controllable even heat
Higher heat efficiency as compared to normal burners
Perfect simmer control, superb for making soup
Burner Performance Comparison Boil 2 litre water
Input: Inner Flame - 3.6kW, Normal Burner - 4.5kW
Heat efficiency: Inner Flame - 403 sec, Normal Burner - 442 sec
Keep Warm Performance: Inner Flame - 142g/h, Normal Burner - 181 g/h
Thank you.
Regards,
Jerome
92256638
Edited by zero
Panasonic 2 door Fridge NRBY602XSG : $1150
Brand : Panasonic
Model : NRBY602XSG
Price : $1150 * free delivery & $150 Voucher
NR-BY602
Maximum Savings, Effortlessly.
● Capacity:
● ECONAVI - Intelligent Eco Sensors
● Intelligent Inverter - Energy savings up to 40% (MELS rating: 4 ticks)
● Vitaminsafe & Moisture vegetable case
● Anti-bacterial deodorizing Ag clean
● Surround cooling airflow
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi Zero,
Can quote me fujioh hood 800MK2? Please recommend me one Fujioh hob with three burners and inner flame, for heavy cooking. I'm alright with glass top or stainless steel.
How much do you charge for installation?
Clearing overstock cookerhood for stock take, LIMITED SETS ONLY!
Cheapest Cookerhood @ $180 * Free delivery only!
- Suction Capacity up to 480m3/hr
- 3 Washeable Metal Grease Filter
- 2 Charcoal Filters
- Colour: Stainless Steel
- Dimension: W900 x D508 x H140 mm
Thank you.
Regards,
Jerome
92256638
Sharp Air Humidifier KCA50E
Brand : Sharp
Mode : KCA50E
Price : $480 *Free delivery
Key Features
•Plasmacluster Ion Shower
•Longer filter lifetime
•New design with bigger opening for water tank and wheels
•Air suction speed is doubled with new design
•Display monitor on unit for easy monitoring
•Humidifying function removes static electricity at a faster rate
Thank you.
Regards,
Jerome
92256638
Toshiba 2 Door Fridge
Brand : Toshiba
Model : GRS20SPBC
Price : $399 *inclusive of mystery gift
Description:
Body Type: Top-Freezer (2 doors)
Total Capacity: 220 L (gross), 186 L (nett)
Dimensions: 547 x 636 x 1354 (mm)
Energy Consumption: 460 KWh
Eco-friendly Certification(s): 3 ticks
Cooling Feature(s): Frost Free
Capacity: Freezer: 58 L (nett)
Capacity: Fresh-Food: 128 L (nett)
Available Colours: Light Gold
Internal Shelves: 1 x Freezer (Plastic), 2 x Fresh-food (Plastic)
Internal Bins: 1 x Crisper Drawer (Plastic)
Health Features: Hybrid Bio Deodorizer
Weight: 41kg
Included Accessories: 2 pcs Ice Twister
Thank you.
Regards,
Jerome
92256638
SMS / Whatsapp / Email for fast response.
Regards,
Jerome
92256638
Edited by zero
HoHoHo!! MERRY CHRISTMAS !!!
KitchenAid Mixer KSM150
Special Xmas price : $6XX
Specifications
Colours available: White, Almond Cream, Empire Red, Onyx Black, Cobalt Blue, Yellow Pepper, Apple Green, Cinnamon, Imperial Gray, Boysenberry, Pink, Pistachio, Ice
- Wattage: Energy efficient 300 watt motor
- Speed Selections: 10 speeds
- Mixing Action: Planetary
- Transmission: Direct drive
- Construction: Full metal construction
- Bowl Size: 4.8 litre
- Mixing Capacity: 1.3kg - Combined total weight of all ingredients
- Tilt Head: 1
- Warranty: 5 years parts and labour against manufacturers faults for household use.
- Standard Inclusions: Flat beater, stainless steel wire whisk, dough hook, 4.8 litre polished stainless steel bowl with handle, pouring shield.
- Height: 35.3cm
- Width: 35.8cm
- Depth: 22.1cm
- Net Weight: 10.60kg
Thank you.
Regards,
Jerome
92256638
Sony 46inch LED TV
Model : 46R452A
Price : $7XX
Enjoy crisp images with reduced noise thanks to Clear Resolution Enhancer. When you’re watching fast-paced action, Motionflow XR 100 delivers smoother, less blurry images so you won’t miss a thing. Now you can also connect your smartphone to view stored media and apps on a supersized Full HD screen.
Clear Resolution Enhancer Picture Engine
Motionflow™ XR 100 for smoother on-screen movement
MHL for instant connection to your Xperia smartphone
Sound Booster for pure audio enjoyment
Super Multi-Format Play
FM Radio
Thank you.
Regards,
Jerome
92256638
Edited by zero
Samsung Vacuum & Navibot clearances sales!
VACUUM CLEANER
Model : SC5250
Price : $69
Easy & Simple,but versatile usage
• Compact & Powerful with portable with high suction power 410W
• Clean exhaust air with EPA H11 filter available which is capable of filtering 0.3μm micro dust up to 95%
• On / off and adjusting power on body for easy to control
Model : VC21F50
Price : $309
Extreme power for perfect cleaning
• 2,100W Power, 450W Suction Power
• 2.0L Dust Capacity
• Twin Chamber System™
• Noise Level 79dBA
Model :VC20F70
Price : $799
Designed to move with you
• 2,000W Power, 360W Suction Power
• Multi Chamber System™
• Cyclone Force Multi
• Dust Sensor
NAVIBOT
Model : SR8750
Price : $569
Air Path Technology which reduces irritating noise and makes it one of the quietest vacuum cleaners
Cliff Sensors that can detect the edges of steps and other deep areas
Virtual Fence that prevents NaviBot entering into specific area
Model : SR8950
Price : $799
Cleaning robot that does your dirty work
• Visionary Mapping™ Plus System
• Slim & Sleek Design
• Dust Awareness Sensor
Model : SR8980
Price : $999
• Auto Dust Emptying System
Thank you.
Regards,
Jerome
92256638
Edited by zero
Samsung Small appliances clearance sales
Microwave
Model :ME731K
Price : $109
Wide black Door with softly curved line
Eco button
Rapid Defrost Feature
Streamline Interior
http://www.samsung.com/sg/consumer/home-appliances/microwave-oven/solo-type/ME731K/XSP
Model :MC285
Price : $329
• Anti-bacterial Protection, Easy to clean, High scratch resistant and discolouration
• Smart Sense that automatically detects humidity and weight of foods, and sets the optimal cooking time and power
• Low standby power consumption, can save 40% on Standby Energy.
http://www.samsung.com/sg/consumer/home-appliances/microwave-oven/convection-type/MC285TATCSQ/SP
Model : CE117PAE
Price : $459
• Smart Sense
• 4 Ceramic Enamel Benefits
• High Scratch Resistance
• Eay to clean
• Anti-Bacterial Protection
• No decolouration
http://www.samsung.com/sg/consumer/home-appliances/microwave-oven/convection-type/CE117PAE-X/XSP
Model : MC32F606
Price : $579
• 32L Convection Microwave Oven
• 900W Microwave output power
• 25 Sensor Reheat / cook menus
• Slim FryTM
• Home-made dough and yoghurt
http://www.samsung.com/sg/consumer/home-appliances/microwave-oven/convection-type/MC32F606TCT/SP
Model : MC455
Price : $699
Featuring SmartSensor technology and six different cooking modes, the Samsung Contrabass Convection Oven helps you quickly, efficiently, and perfectly prepare a great variety of dishes.
http://www.samsung.com/sg/consumer/home-appliances/microwave-oven/convection-type/MC455THRCSR/SP
Thank you.
Regards,
Jerome
92256638
Edited by zero
