ken4228
Wall Drilling Advise & Help Needed
While drilling on my new flat's bedroom walls for clothes hanger, i noticed that the internal walls are hollow.
Googled and found out that it's actually ferrolite walls.
Ferrolite wall: 2cm concrete sandwiched on both sides with a 3.5cm hollow space in between.
My intention is to wall-mount TVs in every bedroom with the heaviest one (22kg) in the MBR.
Can I still use normal concrete wall plugs for the brackets?
If so, will the 2cm thick wall be able to withstand a 22kg 40" TV?
In case anyone is wondering, my estate is Kim Tian Green.
It is HDB's pilot project (guinea pig) for this new kind of wall which uses 20% less sand to erect.
Anyone in Kim Tian Green wall-mount their TVs in the bedroom?
If so, were there any issues and what kind of wall-plug is used??
Thanks for reading...
Bro no worry my estate Clementi Casa wall same as yours coz when installed A/C the hole they drill and hack I saw it clearly
So u r not alone :sport-smiley-004:
