hl124273
How To Interpret This Room Floor Plan ?
1) The stair case is running clockwise. You climb from 9 o'clock and reach 2nd floor at 3 o'clock.
2) Once reach 2nd floor, see 2 doors left and right, one side of the door is to the roof garden and another door is to the room.
3) Once you enter into the room, you will immediately see the toilet entrance that has a bi-fold door
4) The springline is probably some kind of tiled roof.
Thanks. Under the spring line, there is some white space. Do you know if this space can be utilised or void ? If void, I assume it should be crossed out ?
As this floorplan is meant for 2nd floor, it doesn't look like a utilisable space since there is no entrance. Probably an external void space. Perhaps you can take a look a the 1st floor floorplan.
