Please Help Me Take A Look At My Quotation...
  1. 1. So is it expensive?
    • Yes, it is expensive.
      0%
      0
    • Looks ok to me, its reasonable.
      0%
      0
    • No, not expensive at all.
      0%
      0
Please sign in or register to vote in this poll.
Hi, I am renovating my 5rm (116sqm) flat but seems like my quotation cost me slightly on the higher margin compared to my friends who is renovating more parts of their home. So I really need help before I commit into signing the agreement. Loads of things I didn't do... Like Built in cabinets except kitchen, windows & grills, paintings, electrical n etc... Also not inclusive of accessories... But it went above than I have expected. So I appreciate if anyone could take a look at it and feedback. I tried to upload the floor plan but dunno how to... Thanx all in advance...
The quotation is as per below.
Living Room & Balcony
1. Labour charge to dismantle existing 4pcs. Sliding Glass Door including touch up between Living to Living Balcony- $90.00
2. Labour charge to dismantle existing L shape Kitchen cabinet including throw away debris by transport - $160.00
3. Labour charge to dismantle existing Casement Door in Service Balcony ($80) - FOC
4. Labour charge to hack away existing floor tile in Living room, Living Balcony, Study Room, 3 Bedrooms, Bedroom passage way & Store Room - $1,250.00
5. Supply & laying of 60x60cm gloss surface homogenous tiles to Living room,Living Balcony, Study Room, 3 Bedrooms, Bedroom passage way & Store Room flooring including skirting cut from same tiles - $6,160.00
6. Supply & install False ceiling at Main door entrance ( Exclude wiring, light & painting ) - $84.00
7. Supply & install ' L ' box to Living room ( Exclude wiring, light & painting ) - $540.00
8. Living Balcony flooring Topping up with Extruded Polystyrene Foam ( EPF )to level with Living room flooring - $140.00
Study Room
9. Construct of New Wall with 63mm Hollow Block from floor to ceiling height to Study Room( Exclude painting / door & door frame ) - $680.00
10. Supply & install made-to-order Nyatoh Timber Door Frame to Study room - $190.00
11. Supply & install of Nyatoh Solid Door come with Stainless Steel Normal Round Lockset to Study room ( within 3ft x 7ft ) - $270.00
Toilet
12. Labour charge to hack away existing floor & wall tile in 2 toilets - $580.00
13. Laying of water-proofing membrane to 2 toilets flooring - $90.00
14. Supply & laying of 30x30cm floor tile to 2 toilets flooring ( 2 x $330 ) - $660.00
15. Supply and laying of 30x45cm wall tile to 2 toilets wall up to ceiling height - $1,980.00
16. Labour charge to dismantle existing Toilet Bowl & install Owner's New Toilet Bowl ( 2 x $70 ) - $140.00
17. Labour charge to install Owner's Special Wash Basin ( 2 x $80 ) - $160.00
18. Supply & install PD Door ( Slide & Swing system ) to Master Bedroom ( single colour ) - $330.00
19. Supply & install alum. Bronze colour frames Acrylic Bi-fold door, top & bottom c/w tracking to Common toilet entrance ( Within 3ftx7ft ) ( 1 x $180 ) - $180.00
20. Labour charge to seal up existing Common toilet facing Service Balcony with 63mm hollow block - $190.00
Service Balcony & Kitchen
21. Labour charge to hack away existing floor tile in Service Balcony - $180.00
22. Laying of water-proofing membrane to Service Balcony flooring - $60.00
23. Supply & laying of 30x30cm floor tile to Service Balcony flooring - $450.00
24. Labour charge to hack away existing floor & wall tile in Kitchen - $630.00
25 . Laying of water-proofing membrane to Kitchen flooring - $80.00
26. Supply & laying of 30x30cm floor tile to Kitchen flooring - $860.00
27. Supply and laying of 30x45cm wall tile to Kitchen wall up to ceiling height - $2,170.00
28. Replacement of 16mmx12mm Copper piping to Kitchen & 2 toilets ( EXCLUDE hot water piping/tap & heater & any others ) - $860.00
29. Alter Kitchen sink's water inlet and PVC outlet piping and install Owner's tap - $80.00
30. Alter Washing machine water inlet and PVC outlet piping and connect inlet tap - $80.00
31. Construct of Kitchen Sink Concrete with 63mm thick hollow block & tiling up with tiles finished, top c/w cement finished( EXCLUDE Sink, Tap,Door,Shelve & Others ) - $770.00
32. Supply & install alum.Bronze colour frame c/w 2pcs. Acrylic Swing door Kitchen Sink Concrete ( 3pcs. X $90 ) - $270.00
33. Construct washing machine base ( H: 50mm ) with 30x30cm floor tile - $80.00
34. Construct kitchen cabinet base ( H:50mm ) top with cement finished,side with tile finished - $130.00
35. Supply & install of laminate c/w ABS trimming top & bottom kitchen cabinet ( Top ' L ' shape / Bottom straight ) (est. 23.5ft x $95)( Exclude Glass Panel, Kitchen sink, Dishtray, Hob, Hood etc…) - $2,233.00
36. Supply & install Soft Closing Hinge to Cabinet doors Only ( est.27pcs x $6 ) - $162.00
37. Supply & install Soft Pulling tracking to 4 Cabinet drawers Only ( est.4 x $40 ) - $160.00
38. Supply & install of ' L ' shape ' Borelli solid surface ' worktop to kitchen cabinet & Kitchen Sink Concrete ( est. 14.5ft x $75 ) - $1,088.00
39. Construct kitchen cabinet base ( H:50mm ) top with cement finished,side with tile finished ( for vertical cabinet ) ( $50 ) - FOC
40. Supply & install of laminate c/w ABS trimming Vertical kitchen cabinet cabinet, top & bottom c/w casement, centre without door( Exclude Glass Panel etc…) - $520.00
41. Labour charge on Acid washing to whole house wall and floor tiles and Inside window grilles (EXCLUDE outside Window/Grille etc)( $230 ) - FOC
Add on
1. Supply & laying of Pebble Stone ( ' S ' shape ) between Living to Kitchen( yellow & black colour ) - $150.00
2. Supply & install PD Door ( Slide & Swing system ) to Store Room ( single colour ) - $330.00
3. Labour charge to seal up Store door's head ( both side ) with Gypsum cornice( Exclude painting ) - $90.00
4. Supply & install of Tile's Shelving ( 2 layers ) in Master toilet - $150.00
5. Supply & install of ' Bellus solid surface ' Wash basin's worktop to Master toilet ( wall to wall ) - $750.00
6. Construct freezer base (H:50mm) with 30x30cm floor tile ( within 3ft ) - $80.00
Total Cost = $26,284 .....
Electrical Different company coz the ID quote me wayyyyy too much...
1 Lighting point / Fan point c/w switch. 18 nos $ 30.00 $ 540.00
2 Light looping point. 10 nos $ 20.00 $ 200.00
3 13 amp x 1 socket outlet. ( Single ) 2 nos $ 35.00 $ 70.00
4 13 amp x 2 socket outlet. ( double ) 23 nos $ 50.00 $ 1 ,150.00
5 Water heater point. 2 nos $ 80.00 $ 160.00
6 15 amp socket outlet. (Air-con) 1 nos $ 80.00 $ 80.00
7 Telephone point. 1 nos $ 35.00 $ 35.00
8 Network Point ( Cat 5e cable ) 1 nos $ 60.00 $ 60.00
9 Scv t.v point ( 1530A RG 6 cable ) 2 nos $ 90.00 $ 180.00
10 3 core cable to hob / hood.( Heater switch control ) 1 nos $ 50.00 $ 50.00
11 Oven point control by heater switch 1 nos $ 80.00 $ 80.00
12 New D/B board c/w ELCB & MCB. 1 set $ 270.00 $ 270.00
13 Earth point / Earth bonding. 1 lot $ 40.00 $ 40.00
14 Sub-main cable ( meter to DB ) 1 set $ 120.00 $ 120.00
15 Install ceiling fan 1 nos $ 40.00 $ 40.00
16 Install normal light.( Below 9ft ) nos $ 8.00 $ -
Total Cost - $ 3,075.00
