yokine9a
Freelance Plumber
Hi all,
Found a reliable plumber who charge reasonable. A freelance who takes job in plumbing, sanitary works & water heater installation.
His name is Mr Chang & mobile no. is 9752-6120. Just changed my leaking water heater tap recently. As he did a good job, I told him I will help to advertise his service.
Pls try him if you need a plumber. Thanks for reading :)
And can it be that the condition of the water heater can affect the size of the bills? I noticed that I started paying more somehow, although I don’t seem to be using more water than usual, and there was no planned price increase either.
Yeah, I had that happen. The older the water heater, the worse it can work because of scale and clogs, and therefore spend more energy on heating water. The thermostat can break, bad thermal insulation and waterproofing. There are a lot of options basically. Overall, other reasons can also affect the size of the bills, read here https://bens.plumbing/blog/how-to-reduce-your-sewer-bill/. If anything, all this is easily solved by calling plumbers. I can recommend bens plumbing if you’re in Seattle.
