Mounting Opennet And Wireless At The Top Of The Wall
Hi all, my home has just renovated but didn't put Opennet as the previous owner opt out.
MyRepublic offer was hard to resist but just need to find a solution for the cable.
From the external, i guess the Openet would lay the cable through the hole on the right side ? because the other side is where the water and gas pipe is.
I measure and found if i were to lay the cable to where the other boxes and power box is, it would be more than 5 meters
it would also look ugly to lay another cable across
I wonder if this 2nd alternative is possible or have you seen someone done this.
Once the cable comes in they will mount the box at the top so it looks neat. I will also get a holder to hold the wireless router on to the wall. Is this ideal ?
I would also need to put two power point at there ?
Edited by doran_lum
U better build a wall shelf to house your power adaptor also. Openetnhas got ONT, which work like a "modem" in the bb context. On top of that, another wireless router... Can be rather messy...
Maybe u wanna run the trunking beneath your beam? The curtain shd hide it well.
I was talking to a friend and he suggested that they could drill another hole. Have anyone request a OpenNet technician to drill another hole so to minimize the running of the cable ?
Wonder if the below is possible ?
