klbs
Wardrobe Measurement Question
Hi
How does one measure the wardrobe length if I have a ceiling beam at one side of the wall?
Should I measure from the wall or from the edge of the wardrobe?
Thanks.
Forgotten to add that the doors are sliding type, so there is a gap between the wall and the edge of the wardrobe.
Hi, usually the wardrobe specialist will do the measurement for you as they are more expert in this line?
My wife is also dealing with pole system + glass sliding doors.
If you need her advise, feel free to pm me for her details.
Hi Can you pls pm me how much for the wardrobe with pole system + glass sliding doors?Mind do share me the wardrobe picture how is it look like? Thks alot.
klbs, I think we are currently dealing with the same situation as you. We have one huge beam to one side of the room, followed by a smaller recess area on the other side. Our pole system contractor will be building a partition on both sides of the wall as well as on the ceiling, so that a frame can be erected on the partition for the sliding doors. They are quite experienced with these kindda things so if they are worth their salt, they will know how to handle it for you. If you like I can pm you a picture. Hope this helps.
